how do you remove this clip
Old Aug 29, 2009 | 10:43 AM
95greenmaro's Avatar
Default how do you remove this clip
like the title says
Old Aug 29, 2009 | 11:49 AM
dry_kill's Avatar
i think the metal part slides out perpendicular to the injector then you can pull the injector off, not 100% though. might want to wait for someone else to comment
Old Aug 29, 2009 | 06:19 PM
JoeKnowsBaseball's Avatar
You have to cut it off with a sawzall... Be careful not to damage the injector o-rings or not to punch a hole in the intake manifold.
Old Aug 29, 2009 | 06:30 PM
GreatWhiteZ28's Avatar
Dry Kill had it right, the Metal retaining clip slides out then it'll pop right off..
Old Aug 29, 2009 | 07:38 PM
FrankSS's Avatar
its easy, get a small flat tip screwdriver on the closed side of the clip, and it will slide right over.
Old Aug 29, 2009 | 08:15 PM
Powerhouse's Avatar
Cut it off with a torch. Be sure to spray it with brake cleaner while you cut.
Old Aug 30, 2009 | 02:32 PM
FIREHAWK #07's Avatar
wtf lol!!
Old Aug 30, 2009 | 05:48 PM
KidFromThePast's Avatar
I thought it was supposed to be C16 fuel? Helps with the cutting
