Plan on finally starting my Turbo SS tomarrow!!
Thought I would share some more progress pics. All that is left is installing my fuel pump, harness and finish the small stuff tomarrow!!
Got my specialized plates today!!
Originally Posted by BluShadowSS
SSweet setup. what size turbo?
Did not get it running today. I spent most of the afternoon searching for an electric fan. NO way the stock fans will clear no matter what is cut out of the way. Maybe they will fit with a smaller turbo, I don't know. Anyways, I finally found a flex-a-lite 16" lo-boy hi-po fan @ napa in north fort worth and finally got home a little bit ago (trying to spend a little time with the family). Plan on cranking it up tomarrow when I mount the fan and build some brackets.
I'll keep you posted bro!!
Thanks! Master Power T76, 1.00 Exhaust.
I planned on doing this with my setup..... if it wont work you can get 2 12" low pro fans for $50 shipped from Eb*y.
cant you take the factory fans and turn the around to the front and use them as pushers? looks like they would fit in front of the radiator with a little work since the ac stuff is gone.
I used the same flex-a-lite fan on my old ls1 coupe and it never came close to overheating. I should be fine with a single.
Sup Matt! Nick and Sergio stopped by yesterday and shot the **** for awhile. I cranked it up yesterday but the damn belt came off right when it started. I gotta adjust the alt bracket I made and re-test today. I have to work today so it won't be till later tonight. Give me a shout foo!
well you built you **** way faster than i did.....i didnt even start on mine yet. owell hopelfully we can run em when i get home. my current setup has the 76mm turbo in it right now. run before i pull the kit off and put the new turbo on haha
