Hooker headers?
Old Oct 26, 2009 | 09:15 AM
ls1n00b's Avatar
be advised that putting a poly transmission mount may dramatically increase vibration and shaking in the cabin of your car, i had prothane motor and tranny mount done at the same time, and i almost went insane of the vibration.
some cars might make more noise than others,and people have different tolerances,but most on this site seems to think they are not too bad, in my case i could never understand why you would add something that makes your car like that.
Old Oct 26, 2009 | 11:50 AM
02CamaroSSLE's Avatar
im not doing any mounts... motors are not that bad cause i have access to a lift and a trans mount is easy to access n change even if your changin you windshield wipers... so just doin headers ac delco iridium plugs n msd 80mm wires
Old Oct 26, 2009 | 09:54 PM
ORDERED MY HEADERS TODAY!!!
just thought i would let everybody know!!! it's my first "performance" mod since i have owned the car in the past 6 or so months!
Old Oct 26, 2009 | 10:12 PM
RA032926's Avatar
if you grind the 2 bumps down on the trans mount to where they are flat you shouldn't have any vibrations... my car is an m6 though, i'm not sure if there is any difference for a4 cars... i didn't notice any difference as far as noise goes after i did all 3 of my mounts... if you do the trans mount i would advise to do the motor mounts at the same time... i have heard of cases where people only did the trans mount and ended up tearing the case on the trans since the motor was allowed to move but the trans would stay put and eventually cause it to rip because of the torque... i have heard of people doing motor mounts with the headers in but man that doesn't look like fun at all... with the headers out you have an open space right to them and it's a cheap mod... but it's your car do what you please, good luck with the new headers... did you get the painted or coated ones?
Old Oct 26, 2009 | 10:29 PM
coated for sure... only $360 for coated headers... im not sure if i would ever find a deal like that ever!!! i wouldnt mind having painted ones but man do the coated look a hell of a lot better! plus it's not a DD so im sure the ceramic will last n shine for a loong time!
Old Oct 29, 2009 | 08:59 AM
got a set of hookers in last night ordered them from streettweekerz.com for $360 ceramic! anyways ill be installin them friday i hope i can make this p.o.s. used y-pipe will do for now...
Old Oct 29, 2009 | 11:22 AM
98Z2885's Avatar
Thats a good deal, super comps are the way to go imo
Old Oct 29, 2009 | 10:53 PM
00pooterSS's Avatar
Its the tranny mount that causes all that ( i noticed you said the trans mount did it, just adding my .02$ ), I cant even tell I have poly motor mounts. Actually its smoother than the ones I took out because they were so worn. I have been in other types of cars with poly mounts that sucked but seriously I cant tell at all, and thats with using the stock tranny mount. I have a poly tranny mount but never installed it because like you said it causes alot of vibration
