Flashing SES light
Old Oct 23, 2009 | 11:52 AM
03Sssnake's Avatar
Default Flashing SES light
I was on my way to work this morning and as I was getting onto 290 near huffmeiste, I got a flashing SES light. I did get on it from 2nd - 3rd, then the car fell flat on its face and exhaust tone changed. The engine is making no unusual noise, at least no noise that I would expect to hear with a bent pushrod or broken valve spring? I still suspect that is what has happened here. I am going to pull the valve covers tonight and see what I have broken. Just curious if anyone local might have some stock valve springs or a set of push rods they would want to sell.
Old Oct 23, 2009 | 12:19 PM
streetassasin's Avatar
IIRC flashing ses is a lean misfire but Im not 100% on that
Old Oct 23, 2009 | 12:21 PM
TINKRD's Avatar
it means multiple misfires.
Old Oct 23, 2009 | 12:26 PM
03Sssnake's Avatar
TinkRD is correct, I meant to add it is noticeably misfiring and popping..what a way to start the weekend
Old Oct 23, 2009 | 01:07 PM
TINKRD's Avatar
have you worked on the motor lately?
Old Oct 23, 2009 | 01:10 PM
03Sssnake's Avatar
I have not done any motor work, just changed the oil a few days ago. I ran out to pick up a bite to eat 20 mins ago, the car had been sitting all morning since I got to work. Starts up fine, no misfire, and is driving fine until it reaches operating temp, then it starts with the SES light and sputtering and popping. I need to run by autozone and have them pull the code on the way home this afternoon, or I am going to be chasing my tail this weekend.
Old Oct 23, 2009 | 01:19 PM
TINKRD's Avatar
hmm...if you haven't touched the motor, then it could be dozens of things. bad coil pack to bad 02's to bad crank sensor or cam position sensor. good luck chasing your tail this weekend. it's going to be a frustrating one!
Old Oct 23, 2009 | 06:19 PM
03Sssnake's Avatar
come to think of it, the crank position sensor might be a good call TINKRD. I have had some trouble starting the car lately, no noise from starter, no clicking etc, nada. After twisting the key in the ignition it will eventually start on the 3rd or 4th try. I still need to get it scanned and see what codes are being thrown.
Old Oct 23, 2009 | 07:51 PM
JoeKnowsBaseball's Avatar
Also, If you wash your engine bay, you can burn up spark plug wires. I went through 2 sets (free warranty) before I made the connection.
westtexasbuff's Avatar
I have a set of stock valve springs and rods off a '01 WS6 if your interested. Click here for pics. PM me if you want them, I can have them shipped out tomorrow.
Old Oct 24, 2009 | 05:20 PM
03Sssnake's Avatar
I took a look this morning and turns out #5 plug wire was touching the LTs. Fortunately I had kept my old plug wires and its running much better. Thank you all for the suggestions...
Old Oct 24, 2009 | 05:45 PM
dshag's Avatar
check the coils and plug wires, had this hapen in my old camaro and this was problem, mind as well replace plugs too
Old Oct 24, 2009 | 05:47 PM
dshag's Avatar
just noticed u fixed it! little late for me to post
Old Oct 24, 2009 | 07:01 PM
Mike TexaSS's Avatar
8 Sec Tuner
Sounds like a bad crank sensor. Give us a call I can have you back on the road quick!
Old Oct 24, 2009 | 07:18 PM
03Sssnake's Avatar
Thanks guys, the car appears to fixed for a moment. I feel like jackass, was convinced I initially had broken a valve spring, or bent a pushrod since it happened at WOT. I should checked the plug wires 1st..
