Epoxy coating garage floor.. whos done it?
1 Post
u-coat-it is not hard as a rock... you can drop stuff on it, but anything sharp will scratch, so you cant drag jacks sideways or anything like that. and its chemical resistant, but you still need to clean stuff up in a reasonable amount of time or it can stain.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
We have been professionally installing epoxy garage floors since 2004. The purpose of degreasing is not necessarily to get the floor back to its original gray color. It is to open up the pores of the concrete so the epoxy can wick down into the surface.
A simple test: splash a couple of tablespoons of water on a suspect area. If it beads up you've got a porosity problem. If it turns dark in a few seconds the surface is porous and will allow the epoxy to adhere well. Doesn't matter if it is oil stained or not - porosity is the key.
Patrick Dowd
California Concrete Restoration
http://www.squidoo.com/epoxygaragefloors
Patrick Dowd
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
