iphone unlocking?
Old Dec 23, 2009 | 08:40 PM
  #81
ACG's Avatar
ACG
Originally Posted by Domsz06
pissing me off. For some reason 3g will not work. I can surf the web via wifi but not 3g. it's turned on and everything. well off to figure out what happened....
3g doesn't work for t-mobile, you have too turn it off in the settings and use edge for your internet
Old Dec 23, 2009 | 08:42 PM
  #82
Domsz06's Avatar
I don't have tmobile, i have att. and for some reason it stopped working. I'm pissed now!!
Old Dec 23, 2009 | 08:43 PM
  #83
HuMi's Avatar
Originally Posted by onebadblackz
blackra1n.com
sinfuliphone.com
bingo!
Old Dec 23, 2009 | 08:51 PM
  #84
onebadblackz's Avatar
^ thats the best i've had luck with and its the quickest and easiest jailbreak i've done
Old Dec 23, 2009 | 08:52 PM
  #85
ACG's Avatar
ACG
Try a "Reset Network Settings"
Old Dec 23, 2009 | 08:53 PM
  #86
Domsz06's Avatar
i'll try that. Otherwise I'm stumped. anyone suggest a site to help me? like a forum that has smart people
Old Dec 23, 2009 | 09:04 PM
  #87
ACG's Avatar
ACG
http://modmyi.com/forums/
scroll down to you see Jailbreak / Downgrading / Upgrading and click on other methods
Old Dec 23, 2009 | 09:10 PM
  #88
Domsz06's Avatar
thanks acg
Old Dec 24, 2009 | 12:55 AM
  #89
TX RED's Avatar
sweet just did mine
Old Dec 24, 2009 | 09:36 AM
  #90
Domsz06's Avatar
that network reset worked great. Thanks. I didn't know about it.
Old Dec 24, 2009 | 12:00 PM
  #91
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Originally Posted by ACG
My Iphone 3G unlocked for T-Mobile
What did you use to add 5 docked icons and the temp to the status bar?
I use iPhone "Modem" to tether my laptop when traveling, and it was only like $10 - for how much its used, well worth it. I have to run iPhone modem on my laptop and phone... it creates an wireless adhoc network to connect the two - I'm not sure if the other apps do that or not, it was kinda weird at first to figure it out. The speed isn't too bad on 3G, faster than most airport wifi connections actually...
blackra1n, by far the easiest/quickest jailbreak nowadays.
Old Dec 24, 2009 | 12:56 PM
  #92
ACG's Avatar
ACG
In cydia search for Five Icon Dock and WeatheIcon (from ModMyi), when your done installing both of them just drag an app to the bottom for Five Icon Dock. For the WeatherIcon go to your settings scroll down and the app is there, tap on it to open go to Status Bar and turn on Show Image and Show Temp. Then when your done go to your home screen and it should show up.
Old Dec 24, 2009 | 02:44 PM
  #93
-Joseph-'s Avatar
Got it working, thanks!
Old Dec 24, 2009 | 06:57 PM
  #94
JankesGTO's Avatar
Another cool thing.. cydia search hackulos and add the repository. Install Installous.. It will allow you to install cracked apps directly to your iphone on the go. Im on 3.0 modded for text messaging and tethering. I see no reason for me to upgrade to anything more.
Old Dec 25, 2009 | 02:39 AM
  #95
danieloneil01's Avatar
Sorry if this was covered. But another reason to jailbreak. If you have a slingbox you can fool the phone into thinking you're on wifi when you're on 3g and you can watch tv using 3g. Slingbox FTW, but your battery will die in about 30 mins.
Old Dec 27, 2009 | 12:16 AM
  #96
Jinx's Avatar
good luck with the troll bridge on hackulous
Old Dec 27, 2009 | 12:24 AM
  #97
1SLwLS1's Avatar
Old Dec 27, 2009 | 12:52 AM
  #98
Jinx's Avatar
after you add the hackulous repository, and install installous, before you can continue the troll bridge pops up and a password is required to be able to get anything from installous/hackulous.
I would also recommend the Make It Mine app, you can change where it says AT&T to whatever you want, or put something other than the time at the top.
Old Dec 27, 2009 | 12:54 AM
  #99
1SLwLS1's Avatar
I had no password authentication or anything. Just a warning and a continue. weird
Old Dec 27, 2009 | 12:56 AM
  #100
Jinx's Avatar
you must've had it for a while, I had it a while back but just re-jailbroke my phone and found this after installing installous. I already got past it tho LOL!
