Tinted Tails not pass State Inspection?
Rear Reflector
Every motor vehicle shall carry on the rear, either as part of the tail lamps or separately, two or more red reflectors.
Rear reflectors on a vehicle shall reflect a red color.
Red reflectors required on the rear of a vehicle may be incorporated with the tail lamp assembly.
Every reflector upon any vehicle shall be of such size and characteristics and so mounted as to be visible at night from all distances within 600 feet to 100 feet from such vehicle when directly in front of the the lawful lower beams of head lamps.
http://www.txdps.state.tx.us/vi/Misc....htm#blackouts
Also refers to blackouts on there
I could have sworn it was 200ft but I guess I was wrong. Haven't been a inspector in a couple years
A LOT of inspection stations have tightened up recently. Apparently there are several locally that cannot do inspections anymore because they passed cars they shouldn't have. A friend of a friend does inspections and HE wouldn't pass me with door tint that was 4% too dark. The difference between his test panel and my window was negligible... I went home and had to strip the windows... what a pain.
my dad is a cop and say's they are not illegal, as long as they reflect light and you are able to see from 50ft away... like i used to have them on my truck and if you shined light on them they reflected and you could easily see them from 200ft away... but some state inspectors are dicks and cops also and read that law the wrong way... that is just my interpretation...
J
local cops and the dps are totally different i agree ive been certified to do state inspections for 13 yrs now and i was told this by my trooper [dps officer] as long as the reflective properties are in tacht not missing or blocked the car will pass inspection it can have the outside lens part broken and missing but aslong as the reflective material is there its ok !!!
I had that dark smoke tint on my old mustang and they overlooked it here. They did not overlook my loud *** exhaust though lol bt tail lights were fine... just bcuz something isn't legal doesnt mean there isn't a way around it...
Rear Reflector
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thanks again I'm printing it now!
one thing that should be taken into mind...
if someone cant see your taillights and they rearend you because of the fact they didnt realise you just slamed on your brakes...(just an example)
they have every legal right to take you to court... because you intentionaly violated DOT standards.
no different than speeding and hitting someone
