Any one want to help me with ls6 intake Saturday
Old 01-21-2010, 03:50 PM
blubyu02's Avatar
Default Any one want to help me with ls6 intake Saturday
give me a call or text 254 421 1018 i will be doing it in temple, and i will pay good as well, i will do most of the work i just dont want to fu#k nothing up being that i sold my beater and this is my only transportation..........oh im in Temple Texas but dont have to do it at my house i will travel to local areas thanks
Old 01-21-2010, 04:19 PM
speedracer2536's Avatar
come to austin ill bust it out for you
Old 01-21-2010, 05:49 PM
bobbyd's Avatar
get a oil sending unit just in case
Old 01-21-2010, 07:27 PM
blubyu02's Avatar
I may have to taku u up on that speedracer if no one local can
Old 01-21-2010, 07:29 PM
for sure lmk i just did my friends last week. lmk and i have an extra oil sending unit just incase
Old 01-21-2010, 07:30 PM
i have all the tools fyi
Old 01-21-2010, 08:42 PM
LS7 Member
UTzo6's Avatar
Knock out the junk on the bottom of the intake before hand. Use a chisel / flat head and hammer. Sanding them down was messy and annoying...
Old 01-21-2010, 08:48 PM
TechCam97's Avatar
Man if this was next weekend I'd help, I go to Temple every other weekend to see my daughter. This weekend I'm stuck up here in Stephenville.
Old 01-21-2010, 09:04 PM
1QWK408's Avatar
if you come down to webster ill do it for you not a problem send me a pm will take about 45 m inutes
Old 01-21-2010, 09:29 PM
blubyu02's Avatar
I'm deleting egr and air as well would that be a problem speedracer? I don't think ima be able to make it to htown quick thanks tho.
Old 01-21-2010, 09:35 PM
ya that isnt a problem. do you have long tubes? give me a call
5129211934
Old 01-21-2010, 09:39 PM
blubyu02's Avatar
Yeah I got hookers I got the lil block off plate thingys ne thing else I need besides gaskets?
Old 01-21-2010, 09:43 PM
blubyu02's Avatar
Oh and techcam boy did I have some days in good ole stephenville lol even went to granbury a few nights that was bak in the day tho lol
Old 01-21-2010, 11:14 PM
no that should be it man. you will have a check engine light till you get them tuned out though. also do you have these parts
1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788
Old 01-22-2010, 12:41 AM
camAro242's Avatar
this mod is very very easy to do, if your going to do this alone you will need to mod the intake its self,i cant find the pic but here is a vid of a member doing the swap step by step:
https://ls1tech.com/forums/generatio...old-video.html
Old 01-22-2010, 08:43 AM
dude there is no modding to the intake.. you put the intake on there without modification you just have to change the coolant routing..
Old 01-22-2010, 09:39 AM
blubyu02's Avatar
no but i will get them b4 i come
Old 01-22-2010, 12:40 PM
LS7 Member
UTzo6's Avatar
Or you can save money and knock the crap off the bottom of the intake and leave it as is...
Old 01-22-2010, 12:45 PM
TWS
TWS's Avatar
It's a very easy swap, but here's my advice and some of it may repeat earlier posters.
1. Be very careful when you remove the LS1 intake not to break the oil pressure sending unit. There are two vacuum hoses back there. One in front of it and one behind it, so they tend to snag it and break it. Remove it with a buddy, so one of you can hold the hoses away from the sending unit while the other lifts the intake.
2. The gaskets are semi-reusable. Meaning if the LS6 intake has not been off and on a motor more than once or twice, the gaskets should be fine and don't need replacing unless... like I said... the intake has been on and off a bunch of times.
3. I advise NOT changing the coolant routing. Instead I advise taking a dremel, etc. and removing the ribs on the bottom of the LS6 intake in the path of the stock LS1 coolant tubes. That's what I did on my '99 Z28 when I installed an LS6 intake. I prefer to keep the LS1 coolant tubes as I believe it helps with the coolant distro problem that can make cylinder #7 vulnerable. I never removed the coolant tubes. I was lucky to have an extra coolant tube laying on the shelf so I used it as a template and I just marked the path on the bottom of the LS6 and removed the ribs so that everything would clear. Remember to remove enough material where the two plastic holders are for the knock sensor wiring harness to clear them. I think some people have removed those clips, but I kept mine. It's very easy and results in a safer mod than messing around with switching the coolant tubes and you save money by not buying those parts.
