Bubbas solution to the oil spill.
Old May 18, 2010 | 09:29 AM
SHELBY08's Avatar
Default Bubbas solution to the oil spill.
http://www.wimp.com/solutionoil/
Could it work ?
Old May 18, 2010 | 09:43 AM
jbridwelltransam's Avatar
i was laughing at first but those are some serious results and with bp buying the hay it would still be money going into america. I don't know all the technicalities but his water bowl is clean!!
Old May 18, 2010 | 09:51 AM
Vectus's Avatar
Thats pretty cool, yea i think it really could with a few tweaks.
Old May 18, 2010 | 09:53 AM
SHELBY08's Avatar
Yea if it would work I was thinking the same thing about the $$ staying here.
Old May 18, 2010 | 10:54 AM
CarsandWomen's Avatar
thats crazy, so simple its perfect
Old May 18, 2010 | 12:18 PM
sway99bird's Avatar
Wow didn't think that was going to work....
Old May 18, 2010 | 12:25 PM
Jared H's Avatar
Needs an aTm T-shirt in there somewhere to make it "Bubba Approved and Certified" ... seems like a feasible idea ... wonder what it would do to hay prices for cattle ranchers this coming winter.
Old May 18, 2010 | 12:44 PM
Randy_S's Avatar
BP would want to import the hay from another country to save a mickle. He'll, I have 2 acres that I would bail if the price is right.
Old May 18, 2010 | 01:09 PM
tripps's Avatar
That's be funny if they used this tactic. Then the liberals would have to acknowledge a conservative idea as a good one (assuming those 2 guys were conservative)
Old May 18, 2010 | 01:19 PM
Ws6kid.'s Avatar
intresting....
Old May 18, 2010 | 06:47 PM
jdoyle's Avatar
I wonder if the dirty hay could be cleaned in some way once it has been picked up and then redisbursed to accumulate more oil?
Old May 18, 2010 | 07:20 PM
enigmah's Avatar
Its probably the best solution, but they didn't think it up themselves that's why they wont do it.
Old May 18, 2010 | 07:48 PM
02ws666's Avatar
you guys arent thinking right. yes great idea. but you know how much hay it would take? ALOT!!! what happens when you take farmer A's hay away? it will cause a bunch of other problems... i think
Old May 18, 2010 | 08:07 PM
GreatWhiteZ28's Avatar
There was a Tech Professor that had done the same thing but used Cotton instead...it was on Lubbockonline.com the other day..... Guess they do teach some stuff over a old TTU after all...
Old May 18, 2010 | 10:06 PM
whitehooptie's Avatar
Quick answer:
"Hey y'all, shucks let's use hay to soak up the oil," video like it's the ******* cure for cancer, please pull your head out of your *** and think about what you're suggesting. Adding hay to water does not make the two magically disappear. "The area of the spill now exceeds 6,000 sq. miles and more than 11 million gallons of oil are in the sea. That means that the weight of the oil in the water is just over 40,000 tons (7.29 lbs/gallon). Let's assume it takes only 2 ounces of hay per sq. ft. of oil, which seems reasonable, requiring one pound of hay per eight sq. ft. Six thousand sq. miles of oil is 172,232,755,200 square feet. That will require 21,529,094,400 pounds of hay to absorb. Note that these are billions figures. That amount of hay is 10,764,547 tons. So you're going to transport almost 11,000,000 tons of hay to sea to absorb 40,000 tons of oil. Then, after the hay has absorbed the oil, the oil is still in the water. Only instead of having to deal with (a mere) 40,000 tons of oil alone, you've got to scoop up 10,804,619 tons of oil-sodden hay
Old May 18, 2010 | 10:55 PM
mred's Avatar
Originally Posted by whitehooptie
Quick answer:
then the hay becomes a bi-product.
Old May 19, 2010 | 12:32 AM
Ws6kid.'s Avatar
Quick answer:
some one did there home work?
Old May 19, 2010 | 03:19 PM
enigmah's Avatar
Yep but then you have a badass fuel that you can burn and turn into energy, and going by your figures, thats a FUCKLOAD of fuel.
Old May 19, 2010 | 04:27 PM
-Ross-'s Avatar
I heard if you take the hay away all the cows will die.
I like hamburgers.
Old May 19, 2010 | 04:29 PM
02ws666's Avatar
I like hamburgers.
this is exactly what i was indirectly getting at with my earlier post
