Working on Car in a Storage Unit Do's and Don'ts?
I need to get a storage unit for about a month so that I can change my head gasket inside somewhere rather than doing it out in the open so dust and a whole bunch of other junk doesn't get into my cylinders and stuff. my apartment complex doesn't allow car maintenance on the property and I dont want to test them and get my car towed. They have garages but don't do them month to month so I am kind of screwed there too.
so for the people who either store their cars in a storage unit or work on their cars in a storage unit, any tips or pointers? I made my first mistake by telling a place that I was actually going to work on it so they killed that idea pretty quick.
-Are the best locks to buy the round disc-shaped locks? I hear that thieves can't use bolt cutters on those but have to use a grinder instead, which would require a lot more work. Sounds about right to me.
Any help would be greatly appreciated.
Thanks
Thanks
Yeah the disc type locks are the best.
I wouldnt try it in a storage unit. Usually they only have power to the lights no outlets for anything else.
Find someone with a garage to use for a few days, or pay someone to do it for you.
What all are you doing just head gaskets?
I did this once in San Antonio and it worked out fine. Just get one of those light sockets that has a pull string with recepticles on either side. remove the bulb and install it. Tell the company its for car vehicle storage. Dont say another word. Worst case scenerio have someone drop you off there when you get all you **** together. Remember all of them have cameras. try to do the work during the week, less in and out traffic. We used to do all kinds of crap there, I even found others doing the same, cabinet builders,fishing pole builders ect.. You should be alright, just spend a day or 2 goofing around in the unit you rented to get a feel of the place.
hell we had this down to a two hour process on my buddies car we did it so many times.
As far as security. All i have to say is we have about 300 units and yea a disk lock is the best but the lock don't matter to the thief.
thanks for the tip on the locks. i'll be picking up two shortly.
i use to do this a long long time ago before i had access to my own shop or freinds with lifts. i usually had to wait till after 8 pm when management left. however be very careful with this. because if some freak accident happens you will end up liable for it. to me the risk outweighs the benefits
are you talking about something like this where you just unplug what they have in the electrical outlet and then plug in my stuff or something different?
i'd like to do it in a garage but I dont know anyone with an open garage in my area. i moved out to Hutto for work. They only people I know with an open garage are SiL3NtXWS6 and TWS and from what I have seen, Silent's garage space is accounted for and so is TWS'. I already borrorwed TWS' torque wrench, I don't think that I can borrow much more lol!
could you elaborate on this for me please, like with a website to a certain product? I think I know what you are talking about, but I am not positive.
I would pull the light fixture and replace it with a regular outlet, then plug in one of those 8 way outlet splitters in there and use the center screw that comes with it to secure it. Then I would plug in several flourescent shop lights and a couple of ext. cords and fans. The lights and outlet/splitters are cheap and can be found at WalMart. This would give you the much needed light in there. extra outlets for tools plus some air flow.
Depending on what your budget is, the Private Mini storage places have office warehouse space for rent on a monthly basis, and you could do what you needed to without having to hide it. believe it is 500 or so a month for a 10 x 35 unit with a 10 x 17 office with AC.. electric is included.
might be more than you want to spend, but you won't have to sneak around, and you will have 24 hr access in a secure facility.
No, it has light bulb threads on one end and will allow a bulb to be screwed in the other. In the middle is usually 2 receps. one on each side. If I remember correctly I got it at an Ace hardware store. It has a pull chain on it to turn the light on and off once it’s screwed in the light socket.
The threads that the bolt thread into are gone.
Sounds like a good idea. Got any links to this?
Plug the extension cords into spare outlets and enjoy.
Note that the circuit is likely only prepared to handle about 10 amps of draw so try not to run a hammer drill, cage fan and compressor all at once. Keep the tool usage to a minimum and you should be fine.
Hope this helps.
Not a clue, but some of the guys don't use their full hangar and a few cars being worked on still takes up less room than a plane. I'll swing by Hooks Airport after work and look around.
Plus a runway would make a damn good testing ground![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Shoot me a PM with space requirements and length of time if interested.
Hmm.. i think you should get a storage unit if available and cheap otherwise go for garage. I had booked a storage unit for Truck rental in Vancouver, WA. there i have seen many people to working on their car. I never did this by myself, rather i always get a man who can do this for me.
I've had to resort to working on my car at night in the apartment parking lot to avoid getting caught, and even business parking lots. So I know how it is, it sucks not having somewhere to work on your stuff. If you can find a relatively quiet loading dock or something, I would do it there.
Honestly, I wouldn't worry about dust or anything being outside. I changed the head gaskets on my truck outside, doing it in the rain no less. If you've never done them before, give yourself a solid 2 days to finish, and an extra day just in case.
