RCC Twin Turbo Build Update!!
#542
Its a bone stock TR6060. The big HP viper guys have had good luck with this trans. In all reality no transmission can be built to really handle that amount of power and when I decided to go this route I knew the trans was a weak link. Everything on the car has been built or added to handle the power except the trans so Im ok with having to get it rebuilt when it needs it.I believe anytime a car is built to make really big power you have to accept there is some expense in keeping it running. My expense will be in the transmissions.
#543
The TR6060 I got already had one. Dont all the TR6060's have pumps on them?
#545
All the stock pump does is circulate the fluid to the cooler and back to the trans but can be modified to shoot the fluid between 4th & the cluster gear with a nozzle tapped into the case that I highly recommend be done in your case.
