Who can help me fix my car! Want start
Have u messed with ur intake? check if the bolts are lose,if u ever changed it before might wanna check if any gaskets are missing, when I changed my intake at first wasn't getting a good seal, it would idle really high and wouldn't stay on without my foot on the pedal , my intake was sitting on the little vacuum line so I moved it torqued it and now it's fine,hope this helps......
that would suck if this was the case. when you have a broken spring can you hear anything? i can rev the car up fine but once the rpms get low it gets choppy then dies
Joe...its hard for me to explain by typing...but being the first run year for these cars some 98s have had the problem of stretching the harness when the engine is torqued...along with computer problems...not very common but its happened...and sometimes its not problems but flaws that could use improvements
You don't have a check engine light tho? Find someone who can read your codes. There might be some stored that can help diagnose the car.
Is there any way you can get a sould clip of the noise you're hearing?
I would definitely pull the plugs and if that doesn't tell you anything, pull the valve covers. And if it is a spring, they honestly are not that bad to replace, just time consuming and monotonous.
Also, does your oil and coolant look ok ? Make sure it isn't something like a bad head gasket or head problem.
Hope this helps.
-Ernie
oil pressure is good and all when it starts up like 70-75 pounds doesent overheat. i had codes but i only had misfire from when it died and the iat sensor because it was unplugged for some odd reason. ima check the bolts and get a vid up of how it idles
#35
You said u had a missfire,did you fix it? If not pop ur Hood open in a garage with the lights off and check ur coil packs & wires, if any are bad they will throw a spark, u got to watch each one .
#40
Sounds like a problem with spark. If they're covered in fuel, that means you're getting fuel into the cylendar.
Go to autozone and buy a spark plug tester. It should be like a spark plug wire with a "light bulb" that you put between the spark plug and coil. Should only be a couple bucks. If the cylendar is firing, then the bulb will flash at every RPM.
Does the car run at idle without pedaling the gas? Starting to sound like a big intake leak if you're hearing a whistle and it runs rough at idle... Plus if you have an intake leak, the engine will run lean so it will dump in extra fuel to try and even out.
