Who can help me fix my car! Want start
#47
its the stock 98 throttle body. i unplugged the mass air to see if it would idle but it dident so i dont think its the maf. i will look at the gasket. my throttle body does make a weird noise when i turn the key completely off. i dont know what it is or if its always done that
#48
Sounds like a problem with spark. If they're covered in fuel, that means you're getting fuel into the cylendar.
Go to autozone and buy a spark plug tester. It should be like a spark plug wire with a "light bulb" that you put between the spark plug and coil. Should only be a couple bucks. If the cylendar is firing, then the bulb will flash at every RPM.
Does the car run at idle without pedaling the gas? Starting to sound like a big intake leak if you're hearing a whistle and it runs rough at idle... Plus if you have an intake leak, the engine will run lean so it will dump in extra fuel to try and even out.
#52
Idle Air Control is a little solonoid on the throttle body. I think it has two T-20 screws holding it on the top side.... It'll be a cylendar about 2 inches long sticking out the side and when you take it off, it'll have a rod coming out of the cylendar with a cone shapped rubber stopper on the tip.
It's hard to test those without replacing it...
I can't tell you exactly where the crank sensor is, but it's gonna be somewhere near the bellhousing. It will most likely read the flywheel. Not quite sure about these LS1s... I've never messed with one on these cars.
I'd still REALLY like to get some kind of video/sound clip of your car cranking, idling and then giving it gas. Plus the whistling noise would be really helpful to hear. See if you can get one of your buddies or something to figure out how to post it. Try and go through youtube. And don't use a cell phone. They hardly ever work on youtube. Use the newest camera you have access to...
#53
here is the vid of what it does, runs like **** it should have a smooth idle it has a stock cam
http://www.youtube.com/watch?v=qkQm3EwIwSU
#55
It's doing that because you're not wearing a seat belt... lol j/k.
Sounds like a really big intake leak... start searching everywhere on the intake system. If you can get a hold of a "smoke machine" like I mentioned before, use that. It will show you instantly where an intake leak is.
If you can get a smoke machine, try forcing a fog machine (like for halloween and stuff) into the intake. Make it as air tight as possible. Also, you could attatch an air hose from a compressor and feel for air coming out of the intake system. I'm trying to be creative here...
Do you have any intake mods? If so, start searching there first.
#59
I'll say faulty idle control valve, its located on the side of the throttle body, driver side. Hit it a little with the back part of a screw driver and have somebody try to start the engine, if you see any change or it stays running longer, theres your problem.
#60
The engine dying like it did in the video doesn't seem like idle control vavle to me tho. It's more like an intake leak. You can hear when it dies, it's fighting for it. The idle control vavle usually idles up and down for a little and usually only falls on it face with a load on it, such as A/C turned on. The engine doesn't wanna die and that's what makes me think it's a huge intake leak.
