Front end Issue after wheel/Tire change...
ok...well My truck started to shake and shutter under braking after changing to some 20"s.... my truck came with 17's from the factory and the wheel/tire combo I have now is pretty close the being the same size height wise...but now it shaking pretty bad under braking....this is the 1st time I've had this problem ever..... any ideas???
on a side note...it doesn't do it with the stock wheels or tires on....
Possibly, but I bought them through Discount Tire.. gonna run up there tomorrow and have em rebalanced and see if that helps at all..I'm baffled as what it is...and I'm a pretty automotive knowledgeable person....well at least I thought so anyway...
check to see if you have brake clips stock wheels have a recessed area for the clips to set where aftermarket wheels generally dont causing it to not set flush thus giving you a vibration.
if it's only shaking while braking then it is obviously not the balance on your wheels. i would get new rotors, if they are warped, getting them machined isn't going to fix your prob. i'll put $20 that says if you get new rotors and pads that your problem will be gone.
