Help with engine noise "Video inside"
Old Oct 12, 2010 | 02:52 PM
SSHAWK's Avatar
Unhappy Help with engine noise "Video inside"
Ok Texas section you haven’t failed me yet.. I know a lot of people know what certain things sound like when something is wrong so…. if you wouldn’t mind letting me know that would be great.
This is a friend of mines car.
He thinks by the sounds it could be the things he has listed below.
Thinks it’s a lifter or spun rod bearing, possibly with trans noise?
Trying to stop someone from selling their car when it could be something easy to fix.
http://www.youtube.com/watch?v=6fAZNGNYlEc
http://www.youtube.com/watch?v=BaDbzGZitFg
http://www.youtube.com/watch?v=H1DDcEK8c8w
Old Oct 12, 2010 | 02:58 PM
txh0tb0i972's Avatar
Mine sounded just like that before i spun a bearing on mine about 1 yr or 2 ago ! ask bruser or dirty 30
Old Oct 12, 2010 | 03:00 PM
SSHAWK's Avatar
I'm sure Dirty's looking at it now lol
Old Oct 12, 2010 | 03:05 PM
Dirty 30's Avatar
Sounds like you got some rats in the belt driven system.
Old Oct 12, 2010 | 03:06 PM
lol possibly i dont doubt it ....
But yeah about a year ago i was running bruser and dirty 30 and then i heard something weird and we all pulled over and it sounded just like that so i coasted home and then tried to see what was going on so i decided to drive around to the block then thats when it went boom!
Old Oct 12, 2010 | 03:08 PM
SSHAWK's Avatar
lol That helped a lot hahahah
I will tell him to just pick up some of this lol
Old Oct 12, 2010 | 03:16 PM
BadCompany VP WS6's Avatar
I would first of all stop turning it on and take the covers then heads off it.
And holy wiring cluster ****.
Old Oct 12, 2010 | 03:19 PM
SSHAWK's Avatar
Damn that sucks... Dirty sent me a pm on some things he thinks it could be.
I let him know what Dirty said ...We will see what he decides to do.
lol No one said it has to look nice to run good rotfl
Old Oct 12, 2010 | 03:23 PM
dont think its running good though lol jk
Mike TexaSS's Avatar
8 Sec Tuner
Is it a auto car? A broken Flexplate sometimes will sound like the world is ending!
Another easy way to see if its the motor. Is to remove the oil filter and carefully cut the top off and see if the filter is full of metal shavings. Any gold flakes means your motor is TOAST.
Oh yea about 5 seconds into the video im screaming turn that SOB off!
Old Oct 12, 2010 | 03:26 PM
SSHAWK's Avatar
Yes it's a Auto
That's fucked up hahah
Old Oct 12, 2010 | 03:29 PM
I'm glad I'm not the only one. I kept saying STOP STOP STOP and he kept reving it up slowly.
Old Oct 12, 2010 | 03:30 PM
lsjuanmike's Avatar
Hey guys, unfortunately it's my car that is making the noise. Here is some more backup information:
Cam, pushrods, springs, timing and oil pump installed recently and was running fine. Car was acting a fool at the track this weekend, seemed like trans wasnt shifting or jumping gears and I had no power. On the way home the knock and squeek started up.
The car idles at 40 psi oil pressure, but noticed the needle moving a bit up and down, on the drive home pressure was good. When you first start it up it knocks, and the sounds comes from the top of the engine around the intake manifold or top center of engine. As the RPMs increase the sound becomes a bouncing around rattle noise, like rocks in a can bouncing around randomly...not a steady knock.
Then the squeek comes in hard, it drowns out the sound of the knock. That **** is loud under the car and sound like metal on metal rubbing. When I put my ear to where the bellhousing meets the engine it is the loudest.
Engine probably needs mounts, its shaking around in there with the cam.
Checked the plugs and they looked fine. Checked all exhaust connections and things for a metal squeek and could nto reproduce it. Found a tiny metal shaving in the oil from dipstick and some muddy looking oil the first time i pulled the stick but not the next few times. Found nothing in trans fluid.
Would be a bitch if it was all 3 things wrong with it haha
Old Oct 12, 2010 | 03:33 PM
Dirty 30's Avatar
Thats what she said!
I also said the same thing to txhotgirl
LS1x2's Avatar
Formerly 4mulaJoe
Could you get a video of it on spray? Might help. j/k
Sounds pretty distinctly like a broken valve spring/rocker arm/pushrod there at the end of the first video.
Old Oct 12, 2010 | 03:35 PM
Dirty 30's Avatar
Who installed your cam?
8 Sec Tuner
If the oil looks good. You have a broken flexplate.
Old Oct 12, 2010 | 03:37 PM
FlashWS6's Avatar
Destroyer of Exotics
x2 ask me how i know
Old Oct 12, 2010 | 03:40 PM
Dirty 30's Avatar
He just said he found a metal shaving and "muddy oil" which is probably coolant in the oil.
Old Oct 12, 2010 | 03:44 PM
SSHAWK's Avatar
But the next " pulled the stick but not the next few times. Found nothing in trans fluid"
Lets hope for the flexplate lol
