why dont i put up good dyno numbers?
If you can post up a dyno graph so we can see what it looked like that would be a great help. The MS3 does not peak power until 6500 RPM so it needs to be pulled higher. It does need long tubes, I would expect a healthy pick up from doing that. Do you know if the dyno was done with the converter locked or unlocked? You dont have to have a FAST intake to make decent power. The headers would be more important in my opinion. Also, what kind of timing and air to fuel ratio are you running at WOT?
you said built stage 3 from century, what tranny is it? 4l60, 4l80, th400? this is a big variable
EDIT, unlocked converter, theres probly a good 30 wheel horsepower right there, unlocked autos always dyno badly, then ******* haul *** down the track
LS1TECH & Trucks Sponsor
To me it looks like the cam has not peaked power yet. I think if the truck had some long tubes on it, pulled to 6700-6800 rpm, and the converter was locked it would put up some better numbers. With the drive train you are working with I wouldn't be too worried about what it says on the dyno as long as you are happy with how it does on the track. I think it would also be good to know what the timing and air/fuel was on that pull.
First things first ,,,Take it to a reputable shop and have it tuned ,,,,G-force tuned my car and tbss and made a ton of hp....My tbss made 364 with nothing but a cai and cat back after Mike tuned it......
Destroyer of Exotics
quick google search show's
Houston Performance Motorsport
14610 State Highway 249 # 403
Houston, TX 77086-4211
(281) 893-6080
houstonperformance.com
if im not mistaken they deal with more mustang then anything..
(281) 893-6080
#32
yeah, i understand. there is alot of hearsay on this site and people that talk down on the guys that tune their vehicles, to make themselves look better. i have heard good and bad things about every tuner. the guy that did my tune is chuck
#33
I really think a compression or leak down test should be first if you can get the guages for cheap or free, if not, then go with long tubes first and foremost. the ls series responds in great ways to a set of them, an with the heads and cam youve got it will be even better. shortys just dont do much and your trying to move LOTS of volume with em. IF your still not happy, then go with the intake upgrade. a FAST just doesnt compare once you throw the cost factor into the comparison and plenty of people are making really awesome power with the ls6.
still, its an unlocked auto, dont expect big dyno numbers, Bad Chad is right, the dyno is a tuning tool. let your track times tell the tale
#34
let me guess you found him on craigslist and hes charging like $250.00 for a tune?
#35
EXACTLY^^^^^^HE HAS THE WORST REPUTATION.....Take it to G-FORCE please......They are between Alvin and Pearland........
