Help with ball joint...
Old Jan 3, 2011 | 06:41 PM
Fun-Formula98's Avatar
Default Help with ball joint...
I need someone to press out and then press in a ball joint for me. Ill throw a few bucks your way...
Any takers?
Thanks,
Ross
Im in Pasadena.
Old Jan 4, 2011 | 07:31 AM
bump.
Old Jan 4, 2011 | 07:50 AM
TWS's Avatar
TWS
Is the spindle still on the car? If so, whack it with a mallet or deadblow hammer right on the flat spots on the spindle. You will pop the ball joint right out. When you see those flat spots you will know what I mean. Almost look like they were designed for this.
Old Jan 4, 2011 | 07:56 AM
I haven't even taken the wheel off yet. Ball joint will be delivered today so i was about to go get started.
So will this whacking method work for getting the ball joint back in? lol
Old Jan 4, 2011 | 07:57 AM
TWS's Avatar
TWS
haha, no. Might want to have a shop press the new ones in.
Old Jan 4, 2011 | 08:03 AM
Yeah. SO... anyone have access to a press?
Old Jan 4, 2011 | 11:25 AM
Tx91z28's Avatar
you can borrow a ball joint tool from autozone/advance for free (put down a deposit and get it back when you return the tool). i just did all 4 ball joints on my truck it was easy
Old Jan 4, 2011 | 12:42 PM
TWS's Avatar
TWS
^^ If you are talking about a pickel fork, think again. Great way to cut the boots. Use a hammer to knock them out and save the boots.
Old Jan 4, 2011 | 02:07 PM
TehGODofGreen's Avatar
if they are not sealed lube them even if they say they are pre lubed from factory lube again as safety.
Old Jan 4, 2011 | 04:32 PM
rldmachine's Avatar
Default Balljoint tool
A Ball joint tool looks like a c clamp on steroids not like a pickel fork
Old Jan 4, 2011 | 06:41 PM
ORedRoc4's Avatar
I have access to one in La Porte at the ANG unit if you need to use it... Its a 18 ton press and will pop it out. Also autozone does have one you can use that they rent out.
Old Jan 4, 2011 | 07:22 PM
TWS's Avatar
TWS
Sorry, I was just thinking about getting it out.
Old Jan 4, 2011 | 10:29 PM
02CamaroSSLE's Avatar
yeah rent the tool, when you are "pressing" the new ball join back in, take your time and go slow, do not use a impact and after a couple of turns with the wratchet whack the a-arm a couple of time while turning it, it helps getting the ball joint in the right way and not crooked.
Old Jan 5, 2011 | 08:19 AM
Thanks for the input guys. Got it out and back in with the press from Autozone.
