4.8 keeps overheating. HELP??
Old Apr 28, 2011 | 01:50 PM
avengedws6's Avatar
Default 4.8 keeps overheating. HELP??
I have a 2003 RCSB with a 4.8 that keeps over heating. Ive changed the water pump and tstat twice and still pegs the temp at 260. Any idea's?
Old Apr 28, 2011 | 01:55 PM
Ravenous T\A's Avatar
Fans not kicking on, Temp Sensor for the fans?
Old Apr 28, 2011 | 01:56 PM
avengedws6's Avatar
yeah its a clutch fan. I might try the temp sensor.
Old Apr 28, 2011 | 02:09 PM
Pwebbz28's Avatar
If it really at 260 it would be boiling over. Can you hear it boiling after you kill it? I would think if the sensor was bad it would peg out instantly.
Old Apr 28, 2011 | 02:48 PM
Bad Chad's Avatar
Sounds like you have air in the system and need to bleed it. Give me a call and I can tell you how to do it. 281-701-1909
Old Apr 28, 2011 | 02:54 PM
5w20's Avatar
air in system?
check and see if fan(s) work.
coolant level topped off?
If the above 3 things are ok, time to pressurize the cooling system and see if it holds pressure.
Old Apr 29, 2011 | 08:08 PM
avengedws6's Avatar
Thanks was a bad brand new water pump.
Old Apr 29, 2011 | 08:39 PM
ramairracer's Avatar
like said you have an air pocket thats causing it to show hotter than it is,'
Old Apr 29, 2011 | 09:24 PM
mred's Avatar
check to see if there is cold spots on the radiator.
if there are cold spots could be you need a new radiator.
cold spots equals BLOCKAGE
Old Apr 29, 2011 | 11:03 PM
02CamaroSSLE's Avatar
could be a fan clutch also. mine was doing that for a while, never let it get that high though.
Old Apr 30, 2011 | 12:31 AM
avengedws6's Avatar
The impeller was not turning to move the water the way it should, changed the water pump, problem solved, I just didnt believe that a brand new water pump could be bad but it was.
Old May 1, 2011 | 07:01 AM
mred's Avatar
New parts dont mean **** anymore , especially from all the "major parts stores" on each corner that we see.
Old May 1, 2011 | 09:40 AM
dh007's Avatar
Yea new is not necessarly a fix since new parts are made so fast and cheap.
When is the motor gonna be done in the TA ?
