Quick question about rear brake
Old May 17, 2011 | 11:45 AM
Charlie Hustle's Avatar
Default Quick question about rear brake
On my dd 2000 Elcipse, the rear brake is leaking brake fluid. Its to the point where it drains it all out in about 2 days. Anyway, just removed the wheel and I cant seem to tell where its leaking from. The line is secure and not dripping anywhere. It almost seems like its leaking from inside the brake. Has anyone experinced the same problem? Also, Is it just one brake line or are there 2? Thanks in advance.
Old May 17, 2011 | 12:18 PM
5w20's Avatar
one brake line is all i've ever seen
either the wheel cylinder if drum
or the caliper if disc
Old May 17, 2011 | 12:26 PM
Jake_the_Snake's Avatar
get a buddy to step on the pedal while you look. if its leaking out that fast, you'll see it
Old May 17, 2011 | 02:08 PM
Turns out that its the cylinder that was leaking on one end. We replaced it with a new one, but its leaking out more then before when we tap on the brakes. The rubber seals on the side actually come off of the cylinder. The old one wasnt doing this. Did I miss a step when installing the new one?
Old May 17, 2011 | 06:37 PM
DarknessHunter's Avatar
thats not good did you get a new one or used one
Old May 18, 2011 | 06:19 AM
cambirdracing's Avatar
If you press on the brake pedal with out the drum on, it will push the pistons and seals out. You need to stick the drum on about half way to where you can still see the wheel cylinder and have some one push on the pedal.
Old May 18, 2011 | 12:00 PM
like what cambirdracing said, if you press the brakes with the drum off, the shoes have nothing to hit against and the wheel cylinder will pop the seals off if you hit the brakes too hard. chances are that wheel cylinder is still good. just slip the seals back on and install the drum and you should be good
Old May 18, 2011 | 03:09 PM
Thank you both for your replies. I talked to a mechanic buddy and he said the same thing. We were testing it with the drum off. Well once we put everything back together, we messed something up because now the brake is locked up. The car wont even roll foward. cambirdracing, im sending you a pm now, I live in Dickinson.
Old May 18, 2011 | 04:20 PM
Got your message, wrote back.
Old May 18, 2011 | 05:01 PM
If anyones in the Dickinson area and can fix this, Im willing to pay cash. I dont feel like having the vehicle towed to the mechanic, especially if its something simple. I just dont have that much car knowledge. Thanks in advance.
Old May 19, 2011 | 02:38 PM
Bump for anyone that wants to make some cash this weekend. My money spends well
Old May 19, 2011 | 09:34 PM
5w20's Avatar
I can do it if I can find some time.
Old May 20, 2011 | 03:34 PM
Thank you bud. I have a friend that said he would come take care of it this weekend. If for any reason he cant make it or cant fix it, Ill let you know.
