coolant light on
Old Jun 7, 2011 | 09:38 AM
99greenls1's Avatar
Default coolant light on
I have a 99 trans am and the coolant light comes on I check it its full and the resevoir I was thinking the coolant level sensor on the radiator maybe wanted to see what ya think it could be
Old Jun 7, 2011 | 09:49 AM
mike171562's Avatar
The coolant level sensor is a common problem, you can take it out and clean it which should fix it for a while. I ended up just unplugging mine.
Old Jun 7, 2011 | 09:54 AM
99greenls1's Avatar
Ok thanks ill do that see what it does
Old Jun 7, 2011 | 03:07 PM
99zee's Avatar
Very common problem. Drain a little fluid out of the radiator and remove the sensor. You can clean it, replace it or just unplug it.
Old Jun 7, 2011 | 04:41 PM
99SSinOC's Avatar
To help you out since you are new; try using the search tool... (I'm not calling you a tool, I just mean the function... you know..) It's all over the boards. In the future it will solve 99% of your ls1 issues; most any ls1 issue that arises has been addressed at least once in the past.
Old Jun 9, 2011 | 07:10 AM
Bad Blu Formula's Avatar
Unplugged sensor here.
Old Jun 9, 2011 | 08:20 PM
PROFESSORCHAOS's Avatar
I have the same issue on my car and the fluid level is fine, I need to take a look and find that damn sensor?
Old Jun 9, 2011 | 09:33 PM
Spartan7's Avatar
Same place on an LS1.
