question on inspection on 98 z28 in harris county
Old 07-25-2011 | 02:47 PM
11SecVette's Avatar
Default question on inspection on 98 z28 in harris county
will a 98 z28 pass inspection in harris county without cats if there are no codes being thrown?
Old 07-25-2011 | 02:57 PM
ultradriver10000's Avatar
yes they only plug in the odbII and scan for codes.
Old 07-25-2011 | 03:01 PM
Reno's2fastestfbodys's Avatar
depends on the ready status. are you going to delete and go? or have these been deleted (no mil)
Old 07-25-2011 | 03:30 PM
11SecVette's Avatar
how can I tell Reno?
Old 07-25-2011 | 04:53 PM
you can't clear the codes with a scan tool. You need to tune them out via software like hp tuners etc
Old 07-25-2011 | 10:52 PM
<---- has hptuners and am actually scared to do my inspect for Houston to change plates over!!!
Old 07-25-2011 | 10:54 PM
well did you just run down and delete the ses light @ you near by parts store or did someone (prior owner,s) actually take the time or money to delete or put in O2 simulators?
Old 07-25-2011 | 11:33 PM
ElkySS's Avatar
it will not pass. even with them tuned out. if they are tuned out, it will pass when plugged in but if the inspector looks under the car, ur sol
Old 07-26-2011 | 12:09 AM
Crashz28's Avatar
So it wont pass visual but it will pass the computer test if tuned out I can make my own 02 simulators but I was gonna have my egr tuned out I got so many shops that dont check visual. So when you tune them out how does it effect the readyness test? Anybody got a car that has them tuned out that I can scan and check to see for myself
Old 07-26-2011 | 12:33 AM
are you in Houston? im in Katy and work where the inspects are ill do mine tomorrow and let you know how it comes out!!!
Old 07-26-2011 | 09:05 AM
11SecVette's Avatar
Thanks! Yes, Houston
Old 07-26-2011 | 10:44 AM
Cam72aro's Avatar
I used to be an inspector till I changed jobs and don't do them at my current shop. I Needed to get my T/A inspected so I took it to a buddies shop. On the way there I was watching the readiness and had 2 not readies they were o2 and o2 sensor heater. I changed the o2's to no error reporting with hp tuners and reflashed the ecm. I had 1 not ready and did the state on it and passed. You can have 1 not ready. As long as they don't look under the car for cats you will be ok. If they do then just say they are inside the pipes, lol.
Old 07-26-2011 | 01:04 PM
Crashz28's Avatar
So when you tune them out they show up as not ready or not supported?
I really need to get my egr tuned out but I am scared it wont pass the plug in part of the inspection. I don't care about the visual part.
Old 07-26-2011 | 02:53 PM
Cam72aro's Avatar
Its showed ready on mine.
Old 07-26-2011 | 02:56 PM
11SecVette's Avatar
is there a way i can tell if it is tuned properly for this? I am potentially buying a vehicle without cats and the owner doesn't know how it was tuned.
Old 07-26-2011 | 03:03 PM
mine passed today!!!!, no egr, no second air, no 2nd O2's, and turned off (no error or mil send)
TUNED BY ME
Old 07-27-2011 | 09:10 AM
I told you guys it would pass.
My Corvette has no EGR, no cats, no secondary pump, and has a 418cubic inch LS3 and it passes no problem. LoL
I've tuned out many EGR's, Cats, pumps etc with no problems on both f-bodies and trucks.
If you don't have a check engine light it should pass.
Old 07-27-2011 | 11:02 PM
I didnt want to waste my $$$
Old 10-13-2011 | 09:25 PM
phdraperinc's Avatar
I'm in the same boat, no egr, no cats. I just got a ticket today and I just got it running again last week so with my luck I'd find the one place that does do visual. Can i get a pm or a few of places you guys had luck with? Thanks!
Old 10-14-2011 | 09:44 AM
Domsz06's Avatar
if you have hptuners why are you not using it to make the obd2 show ready? that's the great thing about hp tuners you can do that.
I have no cats and I pass hp tuners is the chit!
