Removing Steering Shaft & Water Pump
could anyone tell me/ link me a guide to how to remove the steering shaft and water pump on a ls1 camaro?
My header was rubbing against my steering so i tried fixing without removing it but it didnt work so now im in need to replace it, iv already took the header out and now in the process of taking the steering out. Anyone know how to remove it?
Also while i was down there i saw that my water pump was leaking so since im already down there ill be replacing that too. Idk if im suppose to remove the radiator or what not. Im hoping it wont be a bitch to remove/install![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Any help would be appreciated
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
www.ls1howto.com for the water pump, just look at the cam install. You don't have to remove the radiator.
For the removal of the steering shaft i just basically pry, pray and cuss the sob out?
