Help choosing cam for my ls1
Old 12-06-2011, 02:55 PM
red_diablo's Avatar
Not really into the drag racing scene yet I just wanna have the power there in case I need it seeming that all the new v8s are coming out with over 400 hp
Old 12-06-2011, 02:57 PM
red_diablo's Avatar
What does milled mean???
Old 12-06-2011, 02:58 PM
diablo-Z's Avatar
but ur really worried on drivabilty tho right...or its not a big of a deal?? is it ur daily driver
Old 12-06-2011, 03:07 PM
red_diablo's Avatar
It's my daily... I've never taken it to the trAck... What the difference in a big cam to a small cam drivability wise??? What can I expect ti change??
Old 12-06-2011, 03:08 PM
red_diablo's Avatar
Well it's important but not that important as long as I can get from point a to point b.... From Laredo to San Antonio things like that
Old 12-06-2011, 03:09 PM
bat!'s Avatar
When heads are off the car sometimes they re-surface the head to have a flat surface, which lowers your PTV(piston to valve clearance) basically if they have been milled and you put in a large cam without flycutting the pistons the valves will hit the pistons causing damage.
I don't know why people think the ms3/4 is horrible to drive around with on a stalled car. Seriously it is not that bad its only bad if your tuner sucks. If you want sound it is perfect, and if you want to spray the car later these cams work on the bottle as well. Just get a good set of double springs and go for it. It will sound mean and make good power.
Checkout this link. It makes great power!
https://ls1tech.com/forums/generatio...mparision.html
Old 12-06-2011, 03:35 PM
diablo-Z's Avatar
ur from laredo????? i would say ms3 will be good man...i got a friend that has a camaro running the ms3 cam with stock heads same year as yours for years and he never has problems with it...i got friends running heads n ms3 cam tuned by pat g and there cars r running great and noticed the difference on the gas mileage then before....drivabilty depends on the tuner too...
Old 12-06-2011, 03:48 PM
red_diablo's Avatar
Yea I'm from Laredo bro.... What's the recommended stall for a ms3/4????
Old 12-06-2011, 04:05 PM
diablo-Z's Avatar
ill would go with a 3600 converter with the ms3 cam u will need a ls6 intake tho..
Old 12-06-2011, 04:18 PM
red_diablo's Avatar
Sounds good... How much power will that put down
Old 12-06-2011, 04:27 PM
diablo-Z's Avatar
well depends on what other bolt-ons u gna get....but u can prolly get close to the numbers u want tho
Old 12-06-2011, 04:30 PM
  #32
Pwebbz28's Avatar
LS1Tech 10 Year
Futral f-13 or f-14 cam. There's a reason they don't have a new cam out every 6 months.
Old 12-06-2011, 04:37 PM
  #33
bobbyd's Avatar
that's what I'm wanting once I upgrade from my mti b1 cam.
not sure which will be better though f13 or f14
Old 12-06-2011, 04:42 PM
  #34
Pwebbz28's Avatar
LS1Tech 10 Year
I loved my f14 I had.
http://m.youtube.com/index?desktop_u...?v=w7BfQKunXrA
Old 12-06-2011, 07:44 PM
  #35
diablo-Z's Avatar
f14 specs almost same as the torquer v2 but im sure they got there differances on power
Old 12-07-2011, 09:49 AM
  #36
red_diablo's Avatar
So after about 12 hours or reading and watching videos I've decided to go with a ms3 cam with ls6 intake and heads... 4kstall and some gears...
Now why the cam is out of the way how do I go about choosing gears???
Old 12-07-2011, 10:22 AM
  #37
diablo-Z's Avatar
good choice man u wont be disapointed with that cam............on the gears go with 373's
Old 12-07-2011, 10:23 AM
  #38
diablo-Z's Avatar
motive gears 373's
Old 12-07-2011, 11:24 AM
  #39
red_diablo's Avatar
Who's pat g??
Old 12-07-2011, 11:39 AM
  #40
diablo-Z's Avatar
hes a mechanic/tuner in victoria tx....he does awesome work...u should get ur car tuned by him
Quick Reply: Help choosing cam for my ls1
