Ipod/Iphone hook up to stock radio
It was me... Ive sent you a pm as mentioned but here is a layout for other guys just in case anyone is interested.
Parts:
RadioShack® 1/8" Stereo Panel-Mount Phone Jack
Model: 274-246 | Catalog #: 274-246
$2.69
Speaker wire
Black Tape
Solder
Open the bottom of the radio and what you are going to be looking for is 2 wires that hook up to the cd connector
![](http://www.jason-novak.com/pictures/bottom.jpg)
The two wires are going to be your left and right channel
![](http://www.jason-novak.com/pictures/cdconnector.jpg)
Then you need to follow this diagram as far as hooking it up
![](http://www.jason-novak.com/pictures/274-246.jpg)
Pin 1 - Ground - connect to the stereo chassis
Pin 2 - Left Channel - wire from CD connector on main circuit board
Pin 3 - Left Channel - wire coming from CD player module
Pin 4 - Right Channel - wire coming from CD player module
Pin 5 - Right Channel - wire from CD connector on main circuit board
![](http://www.jason-novak.com/pictures/connector.jpg)
![](http://www.jason-novak.com/pictures/spliced.jpg)
Tape it all up and put it together
Parts:
$2.69
Speaker wire
Black Tape
Solder
So does this kill the CD player?
Yes it is, it has all the connectors to simply plug it in.
When you say CD Player Module, are you referring to the CD player in the radio? Or are the wires we are tapping into wires from the CD Changer Control Port?
Cool. So I see your wiring goes to the front of the radio, did you put the aux jack in the front of your radio?
Do you have an original write up thread?
I used this exact model in my Camaro when I had it.
EDIT - Links don't seem to work, but go to Amazon and search Pac Auxpod/ipac-oem Ipod Interface [universal]
Worked flawlessly and even cheaper on ebay, works in any 00-02 model that has the AUX port on the back for a CD changer (if u have a CD changer u have to disconnect it) it's very simple to use and works great. I may have it somewhere I don't have a need for it if you want it let me know.
The one I linked doesnt have the harness, so you will need to order that as well.
Problem.
The circuit board in my 2002 headunit looks different, anyone know which wires I tap into?
![](http://img716.imageshack.us/img716/1159/img0269sq.jpg)
Uploaded with ImageShack.us
#32
If you have a cassette player, I'd just buy one of those cassette ipod players. I have one for my landcruiser and it works right. I'm interested in doing this to mine, however, I would rather do the cassette option, but my damn hu doesn't have one. 2000 trans am...I need to look up the cabling setup to see if it's like the others otherwise it's time to enjoy an o-scope.
#38
Just tap into CD circuit on board in radio and wala I saw someone do it....
#39
USA Spec Ipod Interface is a really nice unit, IIRC it allows steering wheel controls and charges the Ipod
See them from time to time used on here for sale.
http://usaspec.com/product.php?Produ...eShowProduct=1
