clutch help
Old Jan 9, 2012 | 07:47 PM
02beastly-byrd's Avatar
Default clutch help
Ok guys so i have a couple questions? I have an 2002 Formula Firehawk its a 6 speed an my question is when going to reverse i have to really push it hard an i know that can't b right an sometimes in the gears it grinds! Any suggestions what to do or where to take it an not kill my wallet? I live in La Porte thanks
Old Jan 9, 2012 | 08:07 PM
jaysan's Avatar
Slave cylinder ??? If it's hard to get into gear . But I don't know what could cause grinding maybe someone else will chime in
Old Jan 9, 2012 | 08:13 PM
I think the grinding could b me releasing the clutch a lil to early! Are slave cylinders notorious on these cars the car 90,000 miles
Old Jan 9, 2012 | 09:14 PM
54inches's Avatar
I have found that for reverse if you slip it in another gear first and then reverse it helps.
I agree it does sound like a slave and I am having the same issues on my 05 V.
It's about time for the old LS7 upgrade. Let me know if you need some help chagning it out.
Old Jan 9, 2012 | 09:18 PM
dgcustomz's Avatar
Reverse lockout solenoid.
Old Jan 9, 2012 | 09:19 PM
What put in an LS7 slave cylinder? An ya hopefully that's all it is, do put it in 1st then try going to reverse but it.s the same outcome.
Old Jan 9, 2012 | 09:56 PM
54inches's Avatar
I was saying it is aout time for ME to do the LS& upgrade, which is clutch, flywheel, slave cylinder and then a remote bleed line.
It might be time for you too.
It is about $700 + labor.
BTW, check your clutch fluid.
Old Jan 9, 2012 | 10:06 PM
Thanks man ^^^^^
Old Jan 9, 2012 | 10:48 PM
54inches's Avatar
Update:
Scoggin Dickey has the same kit for $459 or $559 for an Al flywheel.
Old Jan 9, 2012 | 10:57 PM
FasTimeSS's Avatar
Sounds more like ur keys in trans are shot, if ur reverse solenoid was out there is no way it would even grind
Old Jan 10, 2012 | 06:50 AM
Actually i found it goes in alot easier going to 2nd then Reverse! I will keep yall updated
Old Jan 10, 2012 | 03:00 PM
dgcustomz's Avatar
True^^^... I didnt read the grinding part..
Old Jan 10, 2012 | 08:50 PM
Its something fishy going on bc sometimes it goes in without any grinding at all im not sure at all!? Anyone know of a reputable mechanic or shop to fix this
Old Jan 10, 2012 | 09:08 PM
jaysan's Avatar
https://ls1tech.com/forums/texas-mem...only-99-a.html
Old Jan 10, 2012 | 09:20 PM
Thanks!!
Old Jan 11, 2012 | 10:12 AM
jdmoore144's Avatar
It more than likely was something to do with the clutch when it comes to reverse. First and reverse are usually the tell tell signs that it is something with the clutch. If you dont have the money yet, try flushing the fluid and see if that helps. There is plenty of howtos that show you what to do. Now the grinding could be a couple things. Could also be the clutch. Pressure plate might be being lazy or it could be an internal issue with the trans. To help get it around now. Try pushing the clutch pedal a couple times and try to go into reverse. Also you can push the clutch pedal in and hold it in and then go third to reverse. It slows the internals down and makes it easier to go into gear.
Old Jan 11, 2012 | 11:26 AM
Ok thanks dude ^^^
