Callies, Eagle, or K1?
Just wanting some opinions or insight from anyone who's ran their products, about to start my 408 build finally and am trying to decide on which rods and crank to go with, been leaning heavily towards K1 since I'm trying to do it on a budget..(not cheap)
I am running Callies Compstar in my 408 and it seems to be a quality piece and I would say its the best bang for your buck. Im sure it will handle anything you throw at it unless you are doing some crazy build with 1000+hp.
I've decided to go with the K1 crank and rods, they are partnered with wiesco, and have read a lot of product reviews and have yet to come across a bad one, weiso pistons will be going in as well... As far as the HP range I would be guessing it'll be around the 850-900hp range, just an educated assumption just by the results from similar setups... Maybe even a little less since I'll only be running a 78mm..
LS1Tech Premium Sponsor
From first hand experience I can say the K1 and Callies Compstar are virtually identical when it comes to quality of finish and power-handling. Neither require any more machining or finish work before installing in your engine (other than the obvious balancing). Eagle however does have a past riddled with the need for extra work, and this is why we do not offer their crankshafts in our assembled short-blocks.
Let us know if we can help!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
There might be others in Texas that can get K1, but I can tell you for sure none will stock the volume, or offer the pricing we do on it!
__________________
