96 TA Restoration
https://ls1tech.com/forums/lt1-lt4-m...storation.html
I have done it, in the end more hassle than it's worth just to have the only difference being one is ebony and one is dark grey. To make it look right, it just nickel and dimes you to death on what you have to buy to make it look like a factory set up. To start you would need the 00+ dash shell it self, cluster-fog light trim, fuse panel cover, ebony dash cap, hvac/radio cluster bezel, both pillars along with a new glove box door. Then after you do all that, the console would not match, so you would need an 00+ console. And when you finally think your done, the steering wheel will not match so you need a 00+ wheel. When you do that wheel in a LT1 car you need at the very least the clock spring connector or the entire clock spring assembly if you want to keep the air bag working. That's hoping you had a car with a tan or neutral interior, if it was LT1 graphite it will be a shade lighter. I have done the complete ebony interior conversion in my 93, it's a nite mare if you want it to look factory like I did, it's best to source every thing from a single car. Graphite and Ebony can be tough to tell until they are right next to one another.
My first attempt looked like Ray Charles and a group of blind kids sourced the interior, "Hey Kids, what color is that trim piece for the sail panels?" said Ray. The kids replied "I don't know Charles, the guy said Dark grey." Charles then said, "Well did you check?" The kids replied angrily "We are ******* blind like you dick, how are we suppose to check colors when every thing is black because we can't ******* see?"
