Epoxy Garage Floor
Old Jun 26, 2012 | 08:17 PM
daniel044's Avatar
Default Epoxy Garage Floor
Anyone know of a good contractor to do this in Katy area? I would do it myself but I don't want it to peal up first time I drop something on it.
Old Jun 27, 2012 | 06:47 AM
cambirdracing's Avatar
Go to home depot and buy the kit, follow instructions closely. My dad did this on his garage floor that was 7 years old, had all kinds of nasty stuff on it and hasnt' peeled yet.
Old Jun 27, 2012 | 07:00 AM
daniel044's Avatar
I guess its worth a shot. lol
Old Jun 27, 2012 | 07:01 AM
Pipelayaz's Avatar
ucoatit.com
Old Jun 27, 2012 | 07:13 AM
s/c stang's Avatar
I was thinking the same went to home depot bought 2 boxes cause 1 won't cut it, and it did it myself.
Old Jun 27, 2012 | 12:01 PM
Forgot to mention he pressure washed and muratic acid and scrubbed with powdered ajax. Took him a while, but his garage is 3200 sq ft.
Old Jun 27, 2012 | 12:31 PM
chupr0kabra's Avatar
Originally Posted by Pipelayaz
ucoatit.com
This is what I did. I'm very pleased with the results. I did the Rustoleum kit in our old house, and it started peeling after a couple years. The ucoat-it stuff looks the same as when I "installed" it three years ago.
Protip: It's too hot to do this now. You'll get maybe 10 minutes of working time with a batch before it starts to harden. Once that happens, you'll get lumps in your floor.
-Mike
Old Jun 27, 2012 | 12:55 PM
daniel044's Avatar
Yea thats why I was looking for a contractor to do it because its to dang hot out. It may be a fall project. I really like the looks of that ucoatit.com product. My garage is about 500sq ft. so 1 kit should be enough.
Old Jun 27, 2012 | 02:36 PM
sc300's Avatar
here is my floor...
i used the stuff from Sherwin Williams. the good stuff they have, i forgot the name but you can ask the sales guys. two coats of it and then a coat of clear. its around $100 a gallon. i used two gallons each time so 6 total. i just had my painter do it..he just rolled it on just like paint...i waited a day in between each coat.
i have seen the cheap stuff and i think this stuff is so much better and will last for a long time...its thick and doesn't really scratch. its really bonded to the floor, not like the cheap stuff that was just painted on and will peel off.. i dragged my jack around and it only leaves some swirl marks. i guess that was my mistake for using black. i would recommend this stuff, but in the silver color!!!!!!!!!
Old Jun 27, 2012 | 07:21 PM
This gives you some idea of what mine looks like
And this is what happens when it sets up too quickly:
My dad and I did the first two bays in a weekend, then I let that harden for a week before I drove on it. Once the week went by, I moved the car over and did the last bay. Everything blended in really nicely. I did one full kit and a touch-up kit, to make sure I got even coverage. There are a few spots where I didn't clean the concrete well enough, and the epoxy wouldn't adhere, but I went over those enough times that they at least have some protection.
Application is a little odd. You pour out some product, then spread it around with a squeegee. Once it's spread, you roll it, to smooth it out. Finally, toss the color chips, which provide traction when it's wet. I highly recommend this step, as I didn't do it when I did this at the old house, and the floor become a slip-n-slide at the first sign of water.
-Mike
Old Jun 28, 2012 | 08:57 AM
slayer_taunu's Avatar
i did u-coat-it. house was built in 1976, and had all kinds of oil and paint spilled on the floor. i spent a lot of time doing the prep work, and i'm going on 5 years now with no issues with peeling.
only 'issues', is that its scratch resistant, but not scratch proof. dragging a floor jack around will gouge it up. also, its chemical resistant as long as you wipe it up relatively quickly. i was working on my 3rd gen over the course of a month, and i got some anti-freeze trapped under my rhino ramp, and it stained.
Old Jun 28, 2012 | 09:02 AM
Inspector12's Avatar
TT-TECH Veteran
I had www.gallantgarage.com do mine great guy Brett was his name very reasonable for what they do a bunch of colors to choose from etc... Check out the pictures on there website. Its all about the prep work IMO. Good luck!
Old Jun 28, 2012 | 10:47 AM
Camaro Junky's Avatar
Default Epoxy Coat from Lowes
Dude,
If you want epoxy coat, order the kit from Lowes, it is special order only. I put it down myself and it was damn bitch. I did a great job on one side, and then a cold front came through and dried the air and removed the humidity in the air. I did not expect the epoxy to set as fast and I had to sand it for week because as soon as it hit the floor, I could not spread it. It does not come up once it is down.
So when I had to order a new kit, the color was off a tad so heads up and this is known but the company will tell you until you order a different batch of the same color.... My 2 cents is to have a pro do it. Let me know if you want a pic.
When you get the paint chips dirty, they seem to stay that way. But I love the epoxy, it is some bad *** ****!
Old Jun 28, 2012 | 12:21 PM
zman1969's Avatar
I did my own with U-coat it 2 car garage was like 500$ after the discount cards i had (100$ off) holding up well , no pealing 6yrs later. I also did the clear, fleck and grit for traction - if you dont you will bust your A$$ when its wet! trust me its sliprier thans a whales D&%k I also added vinyl graphics under the clear - it ads a nice touch but put them down before the grit do it yourself when it cools off and save the $
Old Jun 28, 2012 | 02:58 PM
daniel044's Avatar
I got a quote today and with warranty they want $900. I dont think that is a bad deal and I dont have to do any work. haha. If I am looking to spend $500 to do it myself and then another 10-15hrs of work in this blaze then I dont think I mind spending $900.
I like doing my own things at the house but I want this done completely right the first time.
Old Jun 28, 2012 | 04:04 PM
TT-TECH Veteran
Yeah sounds reasonable to me to not have to lift a finger etc... Good Luck!
Old Jun 28, 2012 | 04:25 PM
Daniel76's Avatar
Another option that does not involve epoxy or prep or any of that. I'm looking into do my garage (21 x 25) here in the next couple of weeks.
http://www.autogeek.net/racedeck-gar...FVJZTAod-GjILg
Old Jun 28, 2012 | 08:31 PM
99zee's Avatar
Let us know how it turns out. My garage is about the same size and I like that price.
Old Jun 28, 2012 | 09:02 PM
daniel044's Avatar
I will get pics when it's done.
Old Jun 28, 2012 | 10:33 PM
1965GP's Avatar
I used the gray rustoleum kit in our old house and was very happy.
I went with tan in this garage and am not pleased at all. I bought the glossy finish and it is not glossy at all- always looks dirty.
