Help with ? About pulling motor
Old Sep 12, 2012 | 01:05 PM
souljaboy9768's Avatar
Default Help with ? About pulling motor
I have an 02 camaro ls1/t56
In the process of pulling motor and wondering what's the easiest route when pulling motor and tranny together?
From top or bottom?
Old Sep 12, 2012 | 01:36 PM
txh0tb0i972's Avatar
Bottom is the easiest and fastest way
Old Sep 12, 2012 | 02:49 PM
35thPewterZ's Avatar
from bottom for sure... disconnect any lines (fuel and 2 brake lines), hoses, cables, and wiring from body. remove driveshaft, torque arm etc, unbolt tranny crossmemember, then just a few more bolts holding the K-member and youre done... easiest with a lift of course.
oh and dont forget to your shifter boot inside.
with a lift it can be done easily within 2 hrs start to sitting on ground/roll cart
Old Sep 12, 2012 | 03:05 PM
No lift, buy maybe a engine hoist
Old Sep 12, 2012 | 03:18 PM
SLV_WS6's Avatar
your parting out that car right. Cut the front core support. Pull the engine forward and then up with it. You could even cut the cowl then pull it out.
Old Sep 12, 2012 | 04:13 PM
I'm parting out, good idea
Old Sep 12, 2012 | 04:18 PM
CHADsterss's Avatar
Out the bottom worked best for me.
Old Sep 12, 2012 | 04:45 PM
even with no lift, you can unbolt everything and lift the car off the rest faily easy. even though you are parting everything out, whats the point in tearing it all up... someone might want something. i hate getting motors from junkyards that do that for that reason. took more time swapping things over and fixing things than the actual teardown or install.
Old Sep 12, 2012 | 05:08 PM
SLV_WS6's Avatar
The body is junk so he would not be tearing anything up.
Old Sep 12, 2012 | 06:27 PM
makes sense
Old Sep 12, 2012 | 11:07 PM
scj's Avatar
scj
I'll pull it for you in exchange for the spoiler. pm me if interested.
Old Sep 13, 2012 | 10:06 AM
Sent pm
Old Sep 13, 2012 | 10:57 AM
CHADsterss's Avatar
I took me 4 hours to drop my engine and trans out of the bottom. That includes beer drinking and bullshitting, plus a hour lunch break.
Old Sep 13, 2012 | 11:20 AM
nick.celis's Avatar
its just as easy out the top. all matter of preference.
