LMR C7 Heads/Cam Package
#44
Closed ex-Sponsor Account
This is our Stage 1 heads/cam package. This is the Smallest camshaft we offer. Larger cams will be tested next. Still a 87rwhp gain for heads and a baby cam
Again this is the SMALLEST camshaft we are testing. Numbers will only go up from here! Stay tuned!
#47
#53
on a sidenote...I am interested to see if GM has the same issues other MFRs have had with DI and carbon build up intake valve/stems etc...How have they addressed it? The fuel in a traditional setup washes a lot of the build off the valves, not the case with DI, as injection is directly into the combustion chamber. Has GM changed the traditional PCV circuit/path to the intake track, to external setup/cannister away from the intake tract?
crankcase blow-by in RS4, PCV routed back to intake track to burn off blow-by vapors (Direct Injection)
![](http://www.avalonmotorsports.com/blog/wp-content/uploads/2012/03/Ben-Ingraham-RS4-Carbon-Clean-007-WEB.jpg)
#54
After a good weekend of racing in Holly Springs Mississippi, going a personal best of 4.45 @174 on 275 drag radials. We will begin working on the C7 again later on this week! This time we will be trying a little bigger cam to see how it likes it. Stay tuned!
#55
