Houston Area Cam Install Rates
Old 11-18-2013, 11:01 PM
Super Goat's Avatar
Default Houston Area Cam Install Rates
What are the going rates for a cam install and tune at the shops in the Houston Area? I'm looking to get it done soon and just want to see how much I should have saved up. I called Gforce in Pearland and they quoted me $2000, which seemed a bit expensive. Really just trying to get an idea from some people who have had this done.
Old 11-18-2013, 11:08 PM
codyvette's Avatar
It depends what it is in. The cam, springs, oil pump, gaskets, push rods can cost almost a grand so labor for another grand is not all that expensive.
Old 11-18-2013, 11:32 PM
winters97gt's Avatar
I know other shops in Houston that charge 3000 for their cam package. That's not a bad deal from a well known shop.
Old 11-19-2013, 12:06 AM
brett walker's Avatar
Shoot me a pm, Im pretty sure I can get that price beat for you depending on your application.
Old 11-19-2013, 06:16 AM
edub80's Avatar
That is a high price.. can get it done for less a grand most likely..
Old 11-19-2013, 07:09 AM
Super Goat's Avatar
It's on a GTO. I figured $800-1000 to install and around 500-600 to tune. I have all the parts already.
Old 11-19-2013, 07:37 AM
edub80's Avatar
Well u could always get somebody to install the cam and stuff.. then take it to whoever u want to tune.. usually n/a tunes are 500
Old 11-19-2013, 07:49 AM
BT03mach-1's Avatar
just do it yourself it's way more fun!
Old 11-19-2013, 10:17 AM
LSX Power Tuning's Avatar
You will most likely get quoted higher install prices with you having your own parts. The shop isnt making anything on your parts where normally they would make at least a little profit. The second reason is you may be supplying parts they are not used to using or parts they dont sell. If there is a problem related to your parts you will have to pay for labor again where most of the time if the shop supplied the parts they will eat the labor and stand behind a product they sell. When I still had a performance shop 99% of the time when a customer supplied their own parts there were usually issues, missing parts or wrong parts, etc. It took longer for the same job and netted less money in the end so I could easily see why some shops wont even allow customer supplied parts.
Old 11-19-2013, 10:44 AM
03Sssnake's Avatar
Personally I prefer to do it myself, there are good shops out there no doubt, but there is a personal level of satisfaction in doing your own work....There are so many writes up on this site, if you can read, you can do it...
Old 11-19-2013, 12:10 PM
chevelleluvr's Avatar
yep... I would hit up bad chad on here for the install, and he also has someone that tunes as well!
Old 11-19-2013, 12:31 PM
edub80's Avatar
x2......
Old 11-19-2013, 01:04 PM
8 Sec Tuner
Mike TexaSS's Avatar
Gto cam installed with all parts and tune. 2500.00
Old 11-19-2013, 03:29 PM
whatsa347's Avatar
That's who I went too, great guy and knowledgable. Will be back when I install a cam in the new car.
Old 11-19-2013, 04:27 PM
htownws6's Avatar
It depends on exactly what you are going to do. If your installing a cam small enough that you can still use stock lifters and valve springs, you probably could get it done for alot less than 2-3 grand. You wouldn't have to pull the heads in that scenario, that is where alot of the labor is I imagine.
Old 11-19-2013, 04:32 PM
joshtownsend's Avatar
If your not letting bad chad do it.. your getting screwed.. no two ways about it..
Old 11-19-2013, 05:25 PM
Super Goat's Avatar
Thanks for the input guys.
Old 11-19-2013, 06:03 PM
02silverstang's Avatar
That is pretty high I usually do it for $800 if customer has his own parts. plus tune.
Old 11-19-2013, 06:21 PM
Turbo_Stang's Avatar
Do it yourself then take it to PatG.Just one man talking
Old 12-04-2013, 10:27 AM
Tootall's Avatar
it's a little easier if you specify what all you wanted done. To most, a cam swap is just springs/push rods/cam . . .
Quick Reply: Houston Area Cam Install Rates
