Is there anyone around Austin who can delete VATS from my 98 Fbody PCM?
Old 08-10-2015, 10:11 PM
ledesordre's Avatar
Default Is there anyone around Austin who can delete VATS from my 98 Fbody PCM?
Title speaks for itself.
Thanks.
It's for my 76 T/A with LS1 / T56 swap to get it running.
Old 08-15-2015, 07:37 AM
chrysler kid's Avatar
Deleting vats from the ecu will only turn of the security light on the dash. The vats system is controlled by the body control module which you shouldn't be using unless you have converted the interior harness
Old 08-23-2015, 07:04 PM
98TA6.0's Avatar
It wont crank unless VATS is disabled. Not just kill the security light. I would help OP but i just moved to DFW. Lets see the swapped 2nd gen!!! Did you have it posted as a roller on CL? I almost bought a 76 roller that had an LS in previously.
Old 08-23-2015, 07:49 PM
ledesordre's Avatar
BUMP thanks, still need some help with this.
Attachment 722625
nope, wasn't my roller ;0
Old 08-24-2015, 08:30 AM
7beast's Avatar
Nice looking car bud I have a 72 ss camaro with ls6 I finished about 3yrs ago! I can't believe not one person from Austin is chiming in about this.. push come to shove have the pcm shipped to a shop around the Houston area there's plenty people around here that will do that for a little of nothing or ship it to Lsx power tuning in College Station and get a mail order tune while you are at it..
Old 08-24-2015, 10:11 AM
98TA6.0's Avatar
Austin has a shitty LS scene. I could count on two hands how many serious LS guys i knew about. I was always driving to DFW, SA or college station to get parts.
Old 08-24-2015, 10:45 AM
I'm out of the loop on the ls swap wiring into another vehicle but I know deleting the vats in the ecu on fbody cars will not cure a no start problem. the ignition is still routed through the body control module so deleting the vats in the ecu has no effect on the vehicle starting.
However thE OP didn't state why he needed it deleted or the problem it was having
Old 08-24-2015, 12:27 PM
98TA6.0's Avatar
Well im very much in the loop on LS wiring. Ive had to delete VATS on every swap ive done for them to run. The OP needs it deleted to make it......run.
Old 08-24-2015, 02:22 PM
7beast's Avatar
Yes sir 98ta is correct vats has to be deleted no matter what when doing a swap "I'm also in the loop" lol either way this is not the arguement chrysler kid the man needs the vats deleted period
Old 08-24-2015, 07:25 PM
98TA6.0's Avatar
If youre in the DFW area, gimme $100 (for the credits) and ill take care of it. I have a pcm rig set up that i can take care of it with.
Old 08-24-2015, 11:03 PM
No arguments here, if I don't know it I want to learn it. Just consider them free bumps
Old 08-24-2015, 11:17 PM
LSX Power Tuning's Avatar
Thanks for recommend us. Yes if you mail us the pcm we can delete just VATS or delete VATS and do a mail order tune. We tune cars from Austin all the time in person, actually have a vehicle on the dyno right now from Austin.
Quick Reply: Is there anyone around Austin who can delete VATS from my 98 Fbody PCM?
