Summit 6.0 engine blows
We got your engine on the 31st, the very next day (possibly the same day) we let you know it was approved via our warranty and we would take care of it. We’ve identified a problem with some keepers from one of our suppliers that altered the spring height enough to cause premature spring failure (25k miles in your case), if the engine is operated in enough cycles at high RPM. These are Howards valve springs and a very high quality spring.
We have now had your engine in our possession for 3 business days total (we are not open on weekends). Like we informed you, per our warranty we will fix and or replace it depending on the situation at hand. Typically all engines are repaired unless it’s a catastrophic failure, not replaced. We have been in constant communication with you including speaking with your mother today as well as Summit. Also, you did not have to bring the engine 175 miles to us, we offered to pick it up free of charge, this is something you wanted to do.
We are not a small company, the company sells hundreds of thousands of engines a year and we are expediting your claim as fast as we can. In a situation like this, we have to dig into the engine further than just the problem at hand. We had to make sure the valve didn't contact the piston and do major damage. Once we confirm this we need to figure out our game plan, typically rather than just fixing a problem like this, we R&R the entire engine, we don’t believe in band aid fixes, especially with 25k miles of wear and tear on the engine...new machining, new parts, etc...this doesn't happen overnight.
This engine has been very successful for us selling hundreds of them, there are 5 star reviews on Summit, good reviews on here and Performance trucks, etc..its just an unfortunate circumstance.
I really don’t see the issue, we are standing behind our product and trying to get it fixed ASAP, but you come on here and bash us?
If you NEED a truck running now then snag a junkyard 6.0 for the time being then sell it when ATK comes through.
If you NEED a truck running now then snag a junkyard 6.0 for the time being then sell it when ATK comes through.[/QUOTE]
I do need a running truck right now. But the problem is that I began to depend on this truck, I'm already behind on paying work. This truck being down is a burden that I can work around, for now. But its like I said when I responded to ATK's response, I have not posted anything that is not true. I don't expect anything for free, and I am reasonable. I am just sharing a story with other LS1 readers. If I had the time, I would have built an LS motor myself. I did consider using one of the respected builders on this site, but he was too busy to do it in a timely manner that I could work with. But to get back to your statement that I should just buy a junkyard motor, I don't like buying anything from the junkyard if I don't know where it came from. Not bashing anybody that does. I'm 48 yoa and I have gone the cheap route before and it has not always worked out. I do not feel that I cheaped out on this either.
