c5z build thread, dart 427, mast heads, f1r, c6z tr6060!
Old 02-14-2018, 07:49 PM
Silver408z's Avatar
Originally Posted by 01Z0H6
Eric... Is that thing ever going to be done...? Last time I saw/heard it I was in line behind you at WGF.... You going to run this thing again in April?
Your C5Z has come a looong way... SEX!
Eric's car is running. He was having a racepak dash installed on Saturday when I went by the shop. My car is a small budget build compared to his lol. We just have similar looking cars. Doug is my name.
Old 02-14-2018, 07:54 PM
Silver408z's Avatar
Originally Posted by DopeFedZ
Nice build. Should make 950+ pretty easy. My 408 made 950 on 18lbs with the F1R in my Formula.
I made 887 on my 408 and this F1R on 19 lbs. This was just a street tune and then later I put it on a dyno for 2 pulls. No tuning done on the dyno. So there could have been more in it. I have seen some cars make 1000 with a F1R's but its just not as common. I would be very happy to make 950 or 1000 with it. Probably will also depend on how aggressive with the tune we get.
Old 02-15-2018, 08:34 AM
01Z0H6's Avatar
LS1Tech 20 Year Member
My bad....Bad *** build Doug.
Old 02-15-2018, 04:01 PM
Silver408z's Avatar
All good man. Eric's car and my car look very similar, being built by the same shop, close to the same time but I just don't have the budget he does lol. Saturday when I went by the shop every car Bret is working on was silver. It was 5 or 6 cars and they were all silver.
Old 02-16-2018, 11:27 PM
slowredz's Avatar
The bigger motor and especially heads will make the f1r even more insufficient in my opinion. May make more low rpm, but going to run out of steam early in rpms
Old 02-17-2018, 08:10 PM
Silver408z's Avatar
I agree. I will definitely be going bigger but its just not in the budget yet.
Old 02-27-2018, 05:41 PM
Silver408z's Avatar
Some more pics of progress. Bret built some shrouds to enclose and direct air flow. Nothing wrong with more air moving through the intercooler, radiator and condenser. There is also shrouding around the oil cooler but its in the wheel well.
Attached Thumbnails c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9750.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9751.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9754.jpg
Old 02-28-2018, 04:56 PM
Silver408z's Avatar
Got a few more pics of all the work and everything installed back in. The nose was trimmed underneath and even though the cut is not straight it is trued up with the sheet metal work. Also shows some of the sheet metal work on the driver's side for the oil cooler, new air dam and sealing things up to make sure the air goes where we want it and not just the least path of resistance.
Attached Thumbnails c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9773.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9774.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9775.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9776.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-img_9777.jpg
Old 03-01-2018, 10:14 AM
01Z0H6's Avatar
You gonna be running at the WGF event in April? Our C2C2 club has 15 of us running on Sunday 15 April. We'll all pit together as well so we can give each other hell after kicking each others asses! Their are still spots open... Only $275...
Old 03-01-2018, 08:16 PM
Silver408z's Avatar
Yes I am going but I will be there on Saturday. Once the car is running, I will make it to more meets.
Old 03-01-2018, 11:09 PM
Silver408z's Avatar
A couple suspension and driveline pics from when I stopped by the shop today. The coilovers and control arms look great!
Attached Thumbnails c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-20180301_175914.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-20180301_180157.jpg   c5z build thread, dart 427, mast heads, f1r, c6z tr6060!-20180301_180246.jpg
Old 02-09-2019, 10:44 PM
  #32
newchevyman's Avatar
Heard this car is out terrorizing DFW streets!
Old 02-14-2019, 01:27 PM
  #33
383z's Avatar
LS1Tech 10 Year
Shiiiiitt.........I could have seen that coming from Houston.
Old 02-14-2019, 03:55 PM
  #34
imma_stocker's Avatar
Good attention to detail on this build.
Quick Reply: c5z build thread, dart 427, mast heads, f1r, c6z tr6060!
