BIG HP 408 Cu. In. 18* SBC Bowtie Everything Powerplant FS
it is on low boost
Intake to Crank. No oil pan or carb. Brand NEW everything. Bowtie Nascar 2 pc. Intake with removable lifter tray. Comp Ratio 15.5 to 1. 43cc Chamber 18 Degree Bowtie High port cylinder heads flow right over 370/265. Titanium Del West Valves. T&D 1.8/1.65 Shaft Mounted Roller Rockers. Crower offset lifters. Crower Solid roller billet camshaft (Specs upon request). Comp Cams Fully Adjustable Timing Belt (Dry). Wiseco custon Nitrous Pistons (gas ported). BME Billet Aluminum Connecting rods. Callies Pro Series lightweight Crankshaft. 4 Bolt Main from Front to back. High Nickel Content Siamese Bore Bowtie Block (Brand New from GM 2800.00). ALL ARP Hardware From top to Bottom. MSD Crank trigger. MSD Low Profile distrubutor. -EVERYTHING IS NEW NEVER RAN OR DYNOED..$18,000.00 Invested. Sale price $13000.00-obo will consider trades. 713-875-7887 Serious inquiries only please. This combination should make 750fwhp to 825fwhp with the right tune on motor!(1 used BG 400 Fuel Pump $200.00)
I will post *PICS* here in the next couple of days for all of you *PIC* lovers!
Thanks,
Nick
Thanks,
Nick
