Car Troubles..HELP
Old Apr 18, 2005 | 07:51 PM
jdoyle's Avatar
Default Car Troubles..HELP
1999 Z28 M6 105,000 miles
alright, well ever since i raced this WRX (win by the way)and went slightly into the slashed area (normal and red) of the tach but def. not into the all red zone (didnt hit rev limiter), i have heard a little ticking sound coming from the engine. when i rev it, it goes faster and when i idle, it keeps a steady pace. so i went over to a friends house who are good with these cars and they said it was rod knock, which i think i understandable, i thought i needed to lube my belt, hahaha.
so while picking up my window motors and rear end fluid and stuff, i gave them my license and got the code scanner, it gave me p0300 or p 300, which they said is individual or multiple cylinder misifre.
my question is, how can i know which one it really is, hoping its not both? from your personal experience, which one do you think it is? could i have broken a coil pack or sumn, i have checked my plugs by the way, which are tr55s with msd wires if that helps. also, if it is rod knock, does that mean its time for a cam? please, any help is appreciated and also let me know how i did on the car info and symptoms, etc. im only a month into the car.
ps: could i hurt anything by driving like this?
pps: if i do get on it which is only to maybe 3k rpms, everything feels there, doesnt feel like a cylinder is shut down and i have riden in a car with a cylinder down at WOT, if that means flooring it, a plug wire wasnt on all the way.
ppps: if it is time for a cam, wat would you guys recommend for me, what is good for texas daily driving, im reading that FM13 is awesome. also what should i do for surrounding valvetrain?
thanks again dudes.
Old Apr 18, 2005 | 08:29 PM
Saad06's Avatar
heh.. i have the same problem.. i am acutally taking the engine apart tomorrow to look for it.... but if the scanner says misfire... then that probably would be it... but MY guess is that a valve might be out of place or loose and could intern cause misfire?... eh... just my .02
Old Apr 18, 2005 | 08:37 PM
jdoyle's Avatar
well i just went outide to check the plugs and wires, everything seems fine there, the SES went off, so now im even more
my SES comes on every now and then and then goes off a little later, car doesnt run or sound any different, so i kinda disregard it.
but thank you very much for your input.
Old Apr 19, 2005 | 03:33 PM
rayosequis's Avatar
I would try posting this in the internal engine section as they could probably help you narrow down your problem. My guess would be either rod knock or a valvetrain tap. If it is a rod knock, it is basically time for a rebuild. If it is a valvetrain tap, it could be something simple and easy to replace. As for the code, it could hear the mechanical noise and think it is a misfire. If you wanted to narrow it down, try a mechanics stethoscope and see if you can figure out where exactly your noise is coming from.
Hope this helps.
Old Apr 19, 2005 | 04:02 PM
CySevans's Avatar
Same thing happened to me in my Trans Am. Sounds like bent pushrods. They're easy to check. Just pull the coil packs, valve covers, and the rocker arms. I bent a grand total of four of them once.
My recommendation would be to not drive it until you check it out since doing so could cause additional damage.
Old Apr 19, 2005 | 04:33 PM
00 Z-28's Avatar
Bent pushrod?
Old Apr 19, 2005 | 04:36 PM
txhorns281's Avatar
Does someone need help diagnosing which cylinder(s) have misfires? PM me.
Old Apr 19, 2005 | 04:49 PM
CySevans's Avatar
Originally Posted by 00 Z-28
Bent pushrod?
Yes. Do you not know what a pushrod is?
The erratic idling and what-not would be caused by the valves not opening up all the way on the cylinders that are effected. A distinct "ticking" sound is heard because of the gaps between the lifters and the rods and between the rod and the rocker - the overall length of the bent pushrods would be shorter now.
Old Apr 19, 2005 | 05:09 PM
txhorns281's Avatar
unless your exhaust is just too loud then you're just left with that crappy idle stuff... But at the same time it could be ignition related. All these checks are easy, but starting from the outside in would be the way to go!
Old Apr 19, 2005 | 06:33 PM
jdoyle's Avatar
i just have a flowmaster 2 chamber but with the car on and the doors shut you cant hear it at all. i have to actually put my head under the hood to hear it, so i guess its just bent a little bit, are pushrods expensive, can you buy them one at a time?
also when this first started making noise, there was no SES, it was one for like a day then turned off, now no SES. how long would this procedure take, cuz im booked everyday from 7-6? also my idle seems normal, no low or high, idles at like 800-1000 depending on temp. maybe sometimes a little but nothing outrageous
Old Apr 19, 2005 | 08:51 PM
ACW's Avatar
ACW
Hardened pushrods are available (which are more expensive), but you'd probably want to just get a replacement stock one if you don't have a lot of engine upgrades. New from a GM parts dealer they'd probably only come in an pack of 8, but it was suggested in this thread that you might be able to get a single one from a sponsor who has the stock ones left over after upgrading them on customers' cars.
Old Apr 19, 2005 | 11:41 PM
jdoyle's Avatar
alright cool. ill see if i can find one thanks dude
Old Apr 20, 2005 | 12:41 AM
txhorns281's Avatar
Doesn't take long, better safe than sorry, misfires can mean bad things regardless of what the cause.
Old Apr 20, 2005 | 12:46 AM
99BLACKBIRD's Avatar
Shouldn't he go ahead and replace them all? I don't know for sure, but if one bends, I would want all new ones, just so I wouldn't have to change another bent one in the near future.
Old Apr 20, 2005 | 12:54 AM
ACW's Avatar
ACW
Originally Posted by 99BLACKBIRD
Shouldn't he go ahead and replace them all? I don't know for sure, but if one bends, I would want all knew ones, just so I wouldn't have to change another bent one in the near future.
Good point, but since it sounded like he was concerned about the expense, the others don't really need to be done now... :shrug: Another option would be to get the set of 8 but hold the rest in reserve for future replacements
Old Apr 20, 2005 | 11:13 AM
jdoyle's Avatar
well i did pick up one last night, but what i was thinking, if i have a bent pushrod, i might as welll just get a cam and supporting valvetrain, whatdo you guys think?
Old Apr 20, 2005 | 01:40 PM
txhorns281's Avatar
I think your misfires could or could not be related to valvetrain, and you still have no clue which or how many cylinders are the culprit. And should it be a pushrod, turning a pushrod fix into a cam install is like turning a 15 min job into a half day job. Up to you if you have the money
Have you eliminated the ignition yet? That's the easiest place to start (once you know where your misfires are happening). Before you go diving into the motor, try some easier things. Don't be the someone who ran out of gas or something and replaced the whole fuel system instead of obviously filling up.
Old Apr 20, 2005 | 02:47 PM
jdoyle's Avatar
how would i go about checking the ignition and stuff, car always starts up fine hot or cold with absolutely no problems, but i guess that is in the starter department, no sputtering or surging or anything while driving or idling, to me, it drives as fine as it did the day i bought on 3/15/05, lemme know plz thanks alot
Old Apr 20, 2005 | 04:53 PM
txhorns281's Avatar
Ok well the P0300 misifre code on a stock motor (or really any motor, but especially on stock) means something. The fact the you get it intermittently doesn't suggest a pushrod IMO since if you did have a well bent pushrod, you'd have more frequent misfires. Either way, it's helpful to isolate the misfire(s) to their particular cylinders that way you can swap out plugs/wires/injectors/coil packs on each cylinder to see what is the cause. If none of those, then the ignition system can be scratched off the list. When's the last time you did plugs and whatnot?
After that, then you can start looking mechanically. Since you said the car drives well and you don't feel any stumbling, I'm led to believe it's ignition related. There's always the possibility of a goofy O2 also causing disruptive fueling as well. I think you owe it to the car (if you care about it) to be thorough. At 100K these cars do let go of a few things, surprise surprise though considering how hard most of em are driven.
Old Apr 20, 2005 | 10:38 PM
jdoyle's Avatar
ya the p0300 is individual or multiple cylinder misfire, it didnt say which cylinder or how many of them so thats kind of open ended, i have only had this car a month so plugs and wires are still the same ones the guy put on there, ngk tr55s and taylor wires, i spoke to him about the problem and he thinks it is a bent pushrod as well. i have only scanned the car once because the SES will go on and then go off not too long after and i was at the parts store getting window motors and the SES was on so i said hey why not. it really sucks to not have time to work on it and have to rely on it so much, i really dont want to drive it while something is wrong, but i have to get to work and back, drive my sister to school, pick her up, it blows. i always keep it at 2K rpms or lower. i have prom this weekend so im prob gonna check it either or sunday or monday cuz i wanna chugga-a-lug at 100% power.
also, wouldnt i hear something if a piston wasnt firing, or be able to tell if the firing order was out of whack cuz it just sounds wrong? isnt there also an 02 sensor code, or would this be why you said a goofy 02, the car isnt picking up that is bad, but causing surrounding areas to become the center of attention instead?
oh ya, thanks for all the help
