Help me get my broken Arp Crank Bolt out!!!
Just like the title says The Arp Crank Bolt bottomed out for some reason and it broke inside the crank, it's the last 1/4 in. of the crank and it's way in there I already drilled the middle with a 11/64's i believe and i am using the #5 Extractor. should I drill some more to use the #6 easy out? or keep it as is, the only thing is that the extractor is still a good 1/2-3/4 in. within the snout do they sell and extension to get to the extractor and start turning it? thanks,
eddie
eddie
Ouch, I feel your pain man.
I had the same problem about a year back, and even a local machinist couldn't get that piece out. He ended up rethreading the 3" or so on the front of the crank snout to take a larger bolt...
Maybe you'll have more success removing it than I did...
looks like i'm gonna have to drill the whole thing out!! I"m gonna need a 29/64ths drill bit and a m16x2.0 tap anyone know where I can get these relatively cheap? home depot? lowes?
I doubt home depot or lowes would have them. Try your local Napa, they usually have all the hard to find sizes, even if they have to order them. Good luck getting that sucker out.
Originally Posted by LS1INSIDE
found it at napa! now i need the tap or should I use the Arp bolt as a tap?
