Can I borrow a grinder NW Houston
I was having a problem with my poly motor mount
https://ls1tech.com/forums/generation-iii-external-engine/339377-motor-mounts.html
Texas Speed told me to grind off the bottom 2 metal tabs on the poly mount, as it looks to be a mistake from the factory.
Only problem is I do not have a grinder.
I got a couple of Michelob Ultra's in bottles if you can bring on over. Car is on ramps and is undriveable.
Stephen - I have a small bench grinder not mounted to a bench.....
EDIT - just read your other thread - my little bench grinder might work for ya - let me know - I can haul it to work with me tomorrow.
CRZY747 - Wife and I ended up spending the night at the her parents house last night since she was off today. So I didn't get to try it. I told her I needed to get this finished but she doesn't care cause her car is running good.
Brian
for bringing his small bench grinder over. Started putting it back together around 10pm and finished up around 12:45am. Alot of the vibration problem is gone now.
Now I have to do the passenger side.
mmmmmm.....getting thirsty!!!! Need any more tools????
