Idle and Driving Issues...Need HELP
When this happens rings tend to squeeze together. If its a cast ring like a stocker theres not much gap in them from the factory in the first place, they are also high tension rings, and will butt together far more easy then one that is a low tension setup. when this ring butts together there is only one place for it to go. They break or crack the ring land to relieve pressure. This happens on the up stroke of the piston normally. Theres really only one way to find out how serious your motor may be damaged short of tearing into it, a leak down test. If you had an infared gauge you could also hit the primaries and see which one is running hotter or colder then the rest.
Mike
My pistons are as black as black can be. I promise i wasnt running lean by now means. Plenty of carbon on my pistons. If it was lean the piston would be pretty damn clean and light gray to white in color.
Mike
I have an overlay of a x3 and my f14 somewhere... not too pretty....
Mike
Im gonna plug my IAC back up and unplug the MAF to see if its a Fuel Pump Issue or maybe an Ignition Issue. I think the IAC was compensanting for something, either Bad MAF, Crank Sensor, or Fuel Pump or relay?!?!?!? Damn U GREMLINS The Best V8 Stories One Small Block at Time
