HGH question
HGH is a great way to get big real fast, but you still need to lift big, eat HUGE, and get more than the recommended amount of sleep. You also need a solid regimen of PCT (Post cycle therapy), or all of your gains will go straight down the drain, along with all the money you spent.
Before jumping on the steroid bandwagon, hit the basics until you've got a solid foundation. Find a lifting routine that works best for you, and eat a lot of quality meals. Stock up on some protein powder as well, its a quick, simple, and cheap way to get in those extra grams of protein.(Protein intake should be your biggest concern if you plan on getting big/stronger) Creatine is also a relatively safe substance and will help you put on a little bit more mass and help in the recovery process.
Like I said HGH isn't "evil" like most people want you to think, you just have to know your facts and be safe about it. I just don't think its the key for someone who is just beginning to lift. Just my 2 cents, good luck with whatever route you choose!
Arron
If you're looking to bulk up a lot, and have the money, HGH is the way to go!
There is a awesome load of info there. The stuff works very well, I know for myself.
If you have questions, you can PM me. Last edited by INVISIBLEZ; Feb 1, 2006 at 05:03 PM.
There is still nothing better than good ole fashioned Testosterone. It is still the King for mass bar none. Most people equate cost to results when it comes to this stuff, but its simply not the case. The reason recombinant HGH is so costly is because of the cost of the manufacturing process.
Things like Testosterone and Nandrolone(aka Deca) Boldenone(aka EQ) etc etc are so cheap, is because theyve been manufactured synthetically for decades(50+ years in Testosterone's case)
A relatively new one that does work pretty well is lr3IGF1.
Very true statement, but test, decca and all other anabolic steroids only fill your muscles with water, therefore you are "water logged".
HGH actually builds new muscle cells you won't lose, therefore I'd chose the lasting effect. If you couple HGH w/ Test it raises your IGH1 level, and that is the biggest growing factor. People say how much HGH cost, but when you look @ how much you spend time and time again to keep your muscles filled w/ water, or spend a little more and keep the results it's well worth it.
It seems like overnight a certain someones body fat was nearly ripped off, and the gains have been more than awesome w/ the HGH coupled with Test 250 mg. 4 iu's a day of GH, and 700 mg. of test a week of course split dosages. 4 iu.'s is plenty, people start getting the side effects once they go above 6 iu's a day. I could fill the board up with all the info, but I've linked the site that can help those who're curious. I know the gains are partly to do with the test, but I know quiet a few others that have kept the same dosage and time period of 6 mths., and the weight stays on once the cycle is ended.
Before your lung cancer kicks in. Greatest quote ever from a man to a stripper from RedSled to stripper RedSled: "How much?"Stripper: "How much for what?"
RedSled: " For what ever you will let me do?"
Stripper: " How much you got?"
RedSled pulls out Master Card " I got fifty thousand I will buy this bitch."
Okay that will only be funny to a select few but it is still funny as hell.
BOSS APPROVED!
