MSD digital window switch installation?
Old Mar 5, 2006 | 08:35 PM
ap2002's Avatar
Default MSD digital window switch installation?
does anybody know someone in the Houston Area that knows how to install a MSD digital window switch ..... ??
thanks...
Old Mar 6, 2006 | 01:16 AM
MrBill97396's Avatar
any number of the local shops that are sponors here do it
Old Mar 6, 2006 | 08:09 PM
ap2002's Avatar
anybody else?? i know somebody can use a little bit of side money....
Old Mar 7, 2006 | 10:01 AM
ap2002's Avatar
ttt...
Old Mar 7, 2006 | 08:50 PM
ap2002's Avatar
ttt....
Old Mar 7, 2006 | 10:56 PM
lxh89's Avatar
Get a chiltons manual or any other manual that has a wiring schematic. Plug the white wire into the negative coil wire if you have coil on plug ignition. Red wire goes to switched 12V power source, black ground and the yellow connects to the device you want to give ground to when the window switch is ON (selected by the rpm range you specify). Also, for coil on plug setups, set it to 1 cylinder mode.
I am running that switch on my mach 1 for the gas. It's quite easy to hook up if you get a wiring diagram to see whats available to tap into. Use vampire connectors for ease and so that you dont have to cut any factory wiring.
Tony
Old Mar 8, 2006 | 12:25 AM
crAzy95Z28's Avatar
thanks...
i know how..
I have one for my car!
Im in the missouri city area near sugar land!
send me a pm and give me details on what ya want done.
Old Mar 8, 2006 | 01:04 AM
camarossdn's Avatar
I also have one in my car. Just shoot me a pm and let me know. I live in alief area
Old Mar 8, 2006 | 02:04 AM
ap2002's Avatar
pm's sent!!
