A little help....please
Old Oct 17, 2006 | 05:30 PM
sportinss's Avatar
Default A little help....please
I have an 01 SS. Well its inspection sticker time and I cannot get rid of the knock sensor code. Ive deleted them a couple times and it comes right back. Can anyone help me?
Old Oct 17, 2006 | 05:32 PM
Cerebrex's Avatar
What does it say? Does it say low input or what?
Old Oct 17, 2006 | 05:37 PM
Kewl_Blades's Avatar
Where in Texas are you?
Old Oct 17, 2006 | 06:03 PM
sportinss's Avatar
I used an OBD II to delete the codes I just gave a number and a delete option. So I really cant tell you if it was low input or not.
And also Im in Conroe TX, sorry I left that out.
Old Oct 17, 2006 | 06:11 PM
txhorns281's Avatar
Why not just fix the knock sensor issue and be done with codes? It's not expensive, nor difficult. And having functional knock sensors would be a good thing...
Old Oct 17, 2006 | 06:40 PM
sportinss's Avatar
Guess I left some more info. out. Sorry guys, the car has some upgrades cam being one of them, I really think this is what is sending the bad code. I tried to replace it when i first got the code, but after about 10 miles or so it came right back on. that was almost a year ago, i havent tried again since. I guess I'll try that again tomarrow.
Old Oct 17, 2006 | 07:03 PM
SILVER SS 00's Avatar
might be able to help you,where are you located
Cerebrex's Avatar
When you put the intake back on (guessing you took it off), I bet you pinched the knock sensor cable that hooks into the harness. It goes under the intake through a channel to the knock sensors, and it's easy to pinch if you don't pay particular attention to it. A new cable is cheap, and will fix it if that's the problem. Go to Autozone and have them read the codes. If it's low input on bank 1 and 2, that's your problem.
Old Oct 17, 2006 | 07:06 PM
rayosequis's Avatar
On mine (2000), the o-ring on the valley cover for the knock sensor went bad and leaked oil onto one of the knock sensors. Just another thing to check.
