anyone in DFW, near Arlington with a tech 2?
I am having problems with my ABS and my Hptuners wont read and all hptuners can say is "try a tech2" .
Anyone have one that can do a very quick DTC scan? (the ABS and brake light is on)
Originally Posted by White 96LT1
do you mean an OBD2 scanner? go to autozone then?you can use theres for free?
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
Originally Posted by Elite_Hot_Rod
I've got auto tap, it should atleast be able to show you which code it's throwing.
BTW, its on a 98 Ta.
Originally Posted by V6 Bird
No he means what he means...No cheap scanner will read ABS codes. ![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
I can see maybe it could be my car not communicating to the DL connector maybe, but they could at least test it to see if its a bug. I upgraded to their newest release as well.
Originally Posted by Josh McGrath
Yea, I emailed HPtuners support and all they can say is , "Try tech 2..."
Im actually buying one after the holidays. As much as I work on these things, its a must for my garage at home.
youre buying a tech2? Can you modify BCM in any way with that?
Nothing like HPtuners modifying though. It would just be an updated flash version basically.
