Reputable Trans Shops in Houston
17,16,15,14,13,12,11 Drvr
century transmissions in richmond tx. Mike kurtz is the owner and builder of my transmission in the truck, and I will have him build the transmission in the camaro, good luck.
Thanks guys, it still works, but it has ATF starting to seep at the back of the trans. The front seal was seaping but was changed by Speed Demon in 02 when it got the Vigi.
Prety much the exact same trans but with a 5 pin case connector and an extra check ball in the valve body. The 4L60e which most you guys refer to as the 4L60 came in 1994.
Originally Posted by joshtownsend
Does a 93 even have a 4l60..i though it was still the 700r4..?
Originally Posted by BizZzatch350
Some one who can work on a 93 4L60, I dont trust trans shops like Cottman or AAMCO.
Thanks
Thanks
Formerly 4mulaJoe
