78 Trans Am 1.3 hrs southwest of houston
For Sale '78 Trans Am 1.3 hrs SW houston, price reduced!
Black 1978 Trans Am, for pick up! no delivery
description: All black, has rust spots. holes, cracked windshield. All original rims, rear rims has holes for screwing down slick tires.
built for the strip, but has been fixedfor street .
has current registration and inspection. title, clear in hand.
all lights work, has street tires, extended tail pipes still has drag mufflers very nice sound.
trunk is rusted but comes with a replacement fiberglass.
Engine: 350 small block Chevy .040 over
Cubic inches before/after: 350 / 350 Compression ratio: 11:00:1 Fuel: 93-octane super with octane booster Carburetor: 650 double pumper with 80 jets front and 80 jets back, pro-form main body Intake: Edelbrock Victor Jr. Bolts: ARP bolts on heads, mains, oil pump stud & nut, fly wheel Fuel pump: Holley blue 110 gph, 14 psi
regulated to 7.5 psi: on motor and 9.5 on NOS, Fram fuel filter before entering the fuel pump. Fuel Cell: 12 Gallon Summit fuel cell Heads: 64cc Camel back heads with 2.02/1.60 valves, screw-in-studs, guide plates, double springs, 1.6 Aluminum roller rockers, stud girdles Pistons: Keith black .040 over 2-valve relief flat top. Rods: magna fluxed / counter weighted Oil Pump: High Volume Crank: 350 Camshaft: Comp Cams Solid Roller 575/ 575 lift 300/300 duration, 110 lobe separation, double roller chain Camshaft installed position: straight up Ignition: GM H.E.I. with MSD 6A box Total timing: 38' @ 3000 rpm on NOS, 34' @ 3000 rpm on motor Exhaust: small tube headers, 3in. collectors, H-pipe, 3in. dynomax bullets Drive train Info: Transmission: 350 turbo, shift kit, Raybestos clutches Torque converter: 3500 + Jegs Stall Shifter: stock Rear-end: 10 bolt 8.5, stock axles, and 4.10:1 gears Suspension Info: Brakes, front: GM stock disc Brakes, rear: GM stock drums Wheels, front: 15x5, snowflake wheels Wheels, rear: 15x8 snowflake wheels Tires, front: Firestone Fire hawk P275/60R15, 25psi, Tires, rear: goodyear .
Suspension, front: stock Suspension, rear: stock (Leaf Spring) Interior mods: oil and water gauges, Auto Gauge tach w/shift light, Eight point Roll Cage(side bars cut out can be welded back).
ET Info: Best ET ¼ mile: 12.43 @ 107 MPH Motor Best ET ¼ mile: 11.43 @ 121 MPH Nitrous
reason for selling:
dont need a street machine. Im mainly looking for a cruising car, something t-top or topless.
i have never drag raced it, no NOS bottle. the ET's were from the original owner who race it and built the engine, he said engine only has about 10 miles.
missing center caps for wheels on one side. cracked dashboard.
$3,200 or best offer. reduced from $3,900.
reason for selling:
LS1 Tech Administrator
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
You must drive really fast if you can get to Palacios in 1.3 hours from Houston, LOL!
__________________
i run it around town with premium gas, works fine. doesnt need the extra octane booster, unless u wanna race someone. .I try to drive it once a week. I stay away from driving at night and in the neighborhoods. The exhaust is EXTREMELY LOUD!, and these tires will scream during take-off.The rear end is geared for the strip, and 12 gal tank probably wont run very long. depends on how much driving u are gonna do with it. And also there is something drawing the battery down. but i would just put a main switch on the battery, and add an extra tank, should be fine to drive around. i almost forgot, theres a very light oil leak somewhere, trans or eng. oil cover. gotta check it again, but everytime i look at the dipstick it looks fine, and oil pressure gauge looks fine as well. I'll check it tommorrow and let u know about it.
I trust the engine, sounds awesome and brakes work, all lights work. The body just needs to be fixed up, needs rust cut out and replace with new metal, and change the front windshield, it gets annoying with the crack in it. and these tires dont do it justice, need some street slicks, i can't hook up with these, i'll have to try and warm them up. anything else i can think of i'll let u know. or any questions just ask.
later
later
that thing is badass, i would get it but i don't have quite that much
maybe if its still around when i get my tax return
EDIT: do you think the car would make it back to houston
EDIT EDIT: were was it before you got it? and how did you get ahold of it?
