SES And low coolant light
It's probably got plenty of fluid, and just giving you a false light. The fix is to simply unplug it. The sensor is on the radiator right below the cap. Mine even comes on every now and then completely unplugged. It shouldn't set off the SES light BTW, you should get that one scanned.
https://ls1tech.com/forums/showpost....8&postcount=19
It had some SERIOUS mud in the system before I started. It has been clean ever since this was done at 40k miles ago (127k now), fluid changed a few times since for cam swap/head pull/thermostat change. I believe there's more info on the second page as to how you can remove/clean out the overflow tank too.
