tornado and twin electric superchargers...and nitrogen filled tires! How much power??
If you use helium in your front tires you should get a faster front end rise and therefore better traction, but don't use it in the rear tires or your *** will float and you won't go anywhere. As far as the electric superchargers, just get a couple hundred of them and mount them all over the outside of your car and you will get better gas milage. Its true really the 17 year old tech at autozone told me all about it.
P.S. If you let 30 lbs of air out of your tire does it really get 30 lbs lighter???
Ginger Hater
Originally Posted by Greed4Speed
Couple those mods with some nology wires, splitfire plugs, an Ebay performance chip, and the fuel catalyst and you'll be making 500 at the wheels.
