LS2 GTO Heads/Cam Dyno Results....500+RWHP!!!
Old 06-07-2007, 01:13 PM
8 Sec Tuner
Mike TexaSS's Avatar
Default LS2 GTO Heads/Cam Dyno Results....500+RWHP!!!
Last night we finished up TJ's 2006 GTO. It's a VERY clean car that makes some SICK power. The setup is:
Kooks 1 7/8th Longtube Headers w/ Off-Road Connection Pipes
Borla Cat-Back Exhaust
Lingenfelter Cold Air Intake
Trick Flow 215cc Cylinder Heads (Box Stock)
238/242 115 LSA Camshaft
Jesel Shaft-Mount Rocker Arms
Greg Good Ported FAST 90MM Intake Manifold w/ Stock LS2 Throttle Body
A few weeks ago TJ came in for a cam install and the car dyno'd 435 through the stock heads and intake. Then he came back and we did the Trick Flow heads and it made 468. Then he came back again and all we added was the Greg Good ported FAST. That thing picked up 35 RWHP!!! Greg matched it up perfectly to another set of Trick Flow heads we had for another customer and gave us some pointers to make it match up even better when installed on the car. Big thanks to Greg for the work and tips!!
Old 06-07-2007, 01:23 PM
Take 2's Avatar
Nice !!!
Old 06-07-2007, 01:26 PM
Randy_S's Avatar
Damn I need some heads!!!
Good work guys.
Old 06-07-2007, 01:32 PM
JunkyardZ's Avatar
It's hard to believe the ported FAST would pick up more than the TFS heads!!
Good number, sounds like a strong car!
Old 06-07-2007, 01:33 PM
| Powered by Satan |'s Avatar
bad *** mikey!
we need to drink some Millers some time!
Old 06-07-2007, 01:38 PM
SSilverSSurfer's Avatar
damn that dirty, any pics of said car
Old 06-07-2007, 01:43 PM
96-speed's Avatar
Damn! That car picks up 50rwtq over 500 rpm. I bet it feels pretty good right around 4k rpm .
Old 06-07-2007, 02:19 PM
HotRod68Camaro's Avatar
Damn those are sick #s
Not really, im sure if the FAST was put on the car before the heads it wouldn't have picked up as much as it did, and then the car would have seen a much larger hp/tq increase putting heads on after the FAST
Old 06-07-2007, 02:30 PM
JMBLOWNWS6's Avatar
Those are really good numbers!
Old 06-07-2007, 02:32 PM
SUTTERERMAN85's Avatar
i agree fully
Old 06-07-2007, 02:36 PM
8 Sec Tuner
Correct you will see a bigger gain with the FAST when there is a nice set of heads under it.
Old 06-07-2007, 02:44 PM
Shackleford's Avatar
I think I might know this TJ. Is it a blue GTO?
Old 06-07-2007, 02:56 PM
8 Sec Tuner
Yup, Blue GTO with the black wheels.
Old 06-07-2007, 03:10 PM
Old 06-07-2007, 03:29 PM
Black2001z06's Avatar
Why are you guys located so far away???
Excellent #'s btw!
Old 06-07-2007, 03:32 PM
9 Second Club NA
Dragaholic's Avatar
I see that car in Alvin all the time, usually at First National. I've been meaning to ask about that car.
Sick numbers btw.
Old 06-07-2007, 03:36 PM
8 Sec Tuner
That's the one Shackleford.
TJ's company has the 3rd floor of the First National Bank building on 35 and Hwy 6.
2 SLOW's Avatar
Originally Posted by Black2001z06
Excellent #'s btw!
Originally Posted by Dragaholic
Sick numbers btw.
I wonder what my car would dyno at your shop
Old 06-07-2007, 03:38 PM
Yep. I've known the family for years. Good people.
Old 06-07-2007, 03:41 PM
Reznor's Avatar
nice, any vids?
Quick Reply: LS2 GTO Heads/Cam Dyno Results....500+RWHP!!!
