Anyone put in ARP rod bolts?
9 Second Club NA
Pull the pan off and do them one at a time. Be sure to use a torque wrench and torque them down to the required setting. Roll the engine/crank over to access all the bolts.
Some people will that you shouldn't put in rod bolts without new rods, as the aftermarket rod bolts are thicker than the stock ones, causing the cap to deflect.
You could or could not run into issues. I had no issues with my Katech rod bolts.
9 Second Club NA
Originally Posted by Ceissus
i'm not sure what you mean by thicker...does this mean that the bolts push the cap out farther to make a larger ID on the cap side?
Originally Posted by JMBLOWNWS6
And if you going to do that might as well do the motor mounts
