FS: 388 Ci 96 LT1 Stroker w/ T-56 & Wiring Harness + PCM
Alright have this from my car, only 15,000 Miles on the new stroker, with reciepts of all the parts, just put it together not long ago, fixin to go with a full LS1 conversion, engine/tranny/dash and all. Just really trying to see if anyone is interested before I make a decision.
Here is the list of parts/mods to engine/tranny and what would come with engine.
New Wiring Harness
2 PCM's
-Eagle Nodular Iron Crank 3.750"
-LT4 Knock Module
-Hurst Short Throw Shifter
-TB Bypass
-Walbro 255lph Fuel Pump
-Holley Adjustable Fuel Pressure Regulator
-Lucas 42# Fuel Injectors
-5.7" Powdermetal Rods
-KB Hypertectic 383 Pistons 4.060"
-Milodon Full Windage Tray
-Hastings Racing Rings
-Clevitte 77 Racing Bearings
-Comp Cams 468 Xtreme Fuel Injection Cam .579/.584
-1.6 Ratio Magnum Tip Roller Rockers
-Comp Cam Magnum Push Rods
-LT4 Hydraulic Roller Lifters
-Pacesetter LT Headers
-K&N Air Filter
-Ported MAF Sensor
-GM Performance Timing Set (new)
-Cloyes Double Roller Timing Chain (new)
-Rebuilt T-56 (great but still needs 3rd/4th slider)
-180 Thermostat
-Air Foil
-Copper Header Collector Gaskets
-Copper Header Gaskets
-Crane Cams 10308 Valve Springs
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No EGR
-No Cats
-Castrol Syntec 10w30
-LG Performance 2.5 in. Lowering Kit
-ES Motor Mounts (ES = Energy Suspension)
-Melling HV Oil Pump
-7QT Oil Pan w/ Milodon Pickup
-Ported and Polished Heads
-Valve Job
-Ported and Polished Intake
-Ported and Polished Throttle Body
-Valve Locks
-Computer dyno tuned
-Autolite XP Iridium Plugs (new)
-LS1 Ram Air Conversion Intake
-MSD Coil Pack
-March Underdrive Kit
-Chrome valve covers with breather
-ARP Rod Bolts
-ARP Cam Bolts
-ARP Oil Pan Bolts
-ARP Main Stud Kit
-Pioneer Head Bolts
-Oil pan has skid plate, extra pan included
-Powerbond Keyed Balancer Hub (new)
All the following parts are new and just replaced:
MSD COIL
MAP SENSOR
WIRING HARNESS
ALTERNATOR
BALANCER HUB
TIMING SET
PLUG WIRES
PLUGS
OPTISPARK
OPTISPARK HARNESS
o2 SENSORS
o2 EXTENSIONS
TEMP SENSOR IN WATER PUMP
CRANK SENSOR
I know I am probably forgetting some stuff but this is the list.
Will come as full set:
388 CI LT1 Engine
T-56 Transmission
PCM (2 pcm's)
Wiring Harness (2 harnesses, 1 of them is a Spare harness)
Radiator/support/radiator cover etc.
THIS COMES WITH EVERYTHING!
Over $4,000 spent on machine work and parts, and this wasnt for all of the parts, some parts I already had.
![](https://i207.photobucket.com/albums/bb171/mike96z/816814_18_full.jpg)
![](https://i207.photobucket.com/albums/bb171/mike96z/96z4.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/pic0150.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/pic0146.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/0831072329.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/0831072329a.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/0831072330.jpg)
![](http://i207.photobucket.com/albums/bb171/mike96z/0831072330a.jpg)
[IMG]
http://i207.photobucket.com/albums/bb171/mike96z/0831072338b.jpg[/IMG]
Download Vid and Pictures
http://www.sendspace.com/file/vjjraz
Video/Soundclip on Youtube
New Wiring Harness
2 PCM's
-LT4 Knock Module
-TB Bypass
-K&N Air Filter
-Ported MAF Sensor
-180 Thermostat
-Air Foil
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No EGR
-No Cats
-Valve Job
-Valve Locks
-MSD Coil Pack
-ARP Rod Bolts
-ARP Cam Bolts
-ARP Oil Pan Bolts
-ARP Main Stud Kit
-Pioneer Head Bolts
MSD COIL
MAP SENSOR
WIRING HARNESS
ALTERNATOR
BALANCER HUB
TIMING SET
PLUG WIRES
PLUGS
OPTISPARK
OPTISPARK HARNESS
o2 SENSORS
o2 EXTENSIONS
CRANK SENSOR
388 CI LT1 Engine
T-56 Transmission
PCM (2 pcm's)
[IMG]
I dont have much problems with the Gen II, just wanted something different, this engine is a torque monster and im going to loose a **** load of money with pricing this at only $2,500 for everything you will need, thats accesories and all, and transmission, and all wiring and all sensors.
well i found a stock LS1 tranny for $700 and I also found an LS1 with tranny and centerforce clutch and lightweight flywheel complete with harness and all for 3k but i have my transmission guy and he says he can convert my LT1 T56 into LS1 compatable.
yea, im going to go in which ever direction seems feesable, and if someone just needs the motor ill sell it and then sell the tranny separate, someone can use it or can convert to a 6speed from auto, ill have it with flywheel and all.
will you sell the ls1 ram air conversion thing by itself I you will Ill take it just give me a call at 817-277-4962 or 817-897-5783 please let me know something I really want this got cash in hand
